Nusc
- 760
- 2
Light is incidence on a metal surface. For long wavelengths find E and B.
What does it mean when it says for long wavelengths?
What I called k_0 is just what G has outside the square root.Nusc said:What's k0?
What about kappa? from 9.126?
G give (9.126), but doesn't do much with it.Nusc said:How would E and B change if this was an insulator or a semiconductor?
A wavelength is the distance between two consecutive peaks or troughs of a wave. It is typically represented by the Greek letter lambda (λ) and is measured in meters.
Wavelengths are a characteristic property of light. Different wavelengths of light correspond to different colors, with shorter wavelengths appearing as blue or violet and longer wavelengths appearing as red or orange. The entire spectrum of visible light ranges from approximately 400 nanometers (nm) for violet light to 700 nm for red light.
In general, a "long" wavelength refers to a wavelength that is longer than average. However, the specific definition of a long wavelength can vary depending on the context. For example, in radio waves, a long wavelength may refer to wavelengths in the range of thousands of meters, while in the visible light spectrum, a long wavelength may refer to wavelengths in the hundreds of nanometers.
The wavelength of light can affect how it behaves in different mediums. For example, shorter wavelengths are more easily scattered by particles in the air, which is why the sky appears blue. Longer wavelengths, such as infrared light, are less easily scattered and can pass through objects like glass without being absorbed.
Understanding wavelengths is crucial in many areas of science, including optics, astronomy, and telecommunications. Wavelengths are used to describe and measure different types of radiation, such as light and radio waves, and can help scientists determine properties of objects, such as their temperature and composition.
