A What does it mean when the eom of a field is trivially satisfied?
The discussion centers on the implications of a Lagrangian with fields a, b, and c, where the equation of motion for field a is expressed as a linear combination of the equations of motion for fields b and c. It is established that if equations E_b and E_c are satisfied, then E_a is automatically satisfied, indicating a dependency among the fields. Participants emphasize the need for clear definitions of symbols to facilitate understanding, as the original question lacks clarity. The conclusion drawn is that this relationship suggests that only two of the three fields are dynamically independent. This highlights the interconnected nature of the fields within the Lagrangian framework.
Baela
If a Lagrangian has the fields ##a##, ##b## and ##c## whose equations of motion are denoted by ##E_a, E_b## and ##E_c## respectively, then if
\begin{align}
E_a=f_1(a,b,c)\,E_b+f_2(a,b,c)\,E_c
\end{align}
where ##f_1## and ##f_2## are some functions of the fields, if ##E_b## and ##E_c## are satisfied, then ##E_a## is automatically satisfied.
Does this tell us anything particular about the nature of field ##a##?
Without clear definitions of your symbols there's no way to answer your question. Where do you get this from?
Which symbol do you need clarification for? My question is pretty general. I can't see what part you are confused about.
You don't give any definition of your symbols. How can you expect that anybody can understand what they mean?
For background, the OP also started this thread: https://www.physicsforums.com/threa...t-gauge-transformations.1051286/#post-6871749 (although they never returned to it as promised). My understanding of their notation is: ##a(x), b(x), c(x)## are spacetime fields individually satisfying the 3 Euler-Lagrange (field) equations ##E_{a}(a(x))=0, E_{b}(b(x))=0, E_{c}(c(x))=0##. I think they want to know the consequences if ##E_{a}(a(x))## happens to be a linear-combination, with field-dependent coefficients, of ##E_{b}(b(x)),E_{c}(c(x))##. My answer is that it simply means only 2 of the 3 fields are dynamically independent.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
