What does it take for a material to be transparent to light?
In summary: Gamma rays are not an issue in the solar radiation, however, and the atmosphere can block most of them.
refind
51
I need help exploring this question: what makes a solid transparent/opaque?
If I have clear sheet of plastic and I introduce imperfections (such as small air bubbles inside), it turns white if the # of imperfections is large. Is it possible to maintain the polymer transparent with such air pockets inside? If bubbles are made very small (say taking the limit as diameter -> 0), would that do the trick?
Any input appreciated.
Science news on Phys.org
firstly you need to define what frequency of light you are interested in.
materials opaque or near opaque to visible light may well be transparent to IR or UV light
or any combination of those
Maybe you are just asking a generalised question ?
Dave
any material is transparent if the frequency is high enough.
For visible and below, a nanoscale uniform dielectric like glass, monocrystalline aluminum oxide or many thermoplastic polymers are pretty good.
Porous materials are not transparent due to microscale scattering centers like air pores.
I'm interested in visible light, so frequency is constrained. What would it take to make a thermoplastic polymer with impurities be transparent to visible light frequencies? If I can make the air bubbles very small (few nm), would that do the trick regardless of impurity shape and density (number of bubbles per unit volume).
Are there any theories/papers on this subject that may be helpful?
Thanks!
Thanks!
try plastic wrap for food.
What? If this were true, what would be the point of sunscreen? If anything, it would be lower frequencies that are more transparent, at least from what I've seen. Would I need to worry about gamma rays from a nearby supernova?
what do you mean "try" it?
Depends on what material. Lower frequencies are more transparent to dielectrics but have no hope of going through conductors. When I say low frequencies I mean frequencies below the plasmon frequency. For frequencies above the plasmon frequency the metal is transparent.
Sunscreen is special in that it has molecular transitions in the near UV energy range that gets through to earth.
plastic food wrap is transparent. it is also a thermoplastic.
A porous but not absorbing material appears white as the light scatters on the pores. That can be reflection at the interface of the bubble and the matrix, or diffraction on the small imperfection. The rays coming from a light source will not travel in the original direction, you can not see it through the sheet of material. The scattering depends on the relative size of the pores with respect to the wavelength. Bubbles, size of a few nanometer do not scatter visible light appreciably. Scattering also depends on the refractive indices of the material filling the bubbles with respect to the matrix itself. White paper is not transparent, but transparency improves if you soak it in oil.
If you want a professional article about porous plastics, see http://www.lbl.gov/Tech-Transfer/publications/2519pub.pdf for example.
ehild
"High enough" is in the range of x-rays and gamma rays. You need a lot of material to block those. They are not an issue in the solar radiation, however, and the atmosphere can block most of them.
Only if it is very close to us.
FAQ: What does it take for a material to be transparent to light?
What is the definition of transparency?
Transparency refers to the property of a material to allow light to pass through it without significant scattering or absorption.
What determines a material's transparency to light?
A material's transparency to light is determined by its molecular structure, which dictates how light interacts with the material's atoms and molecules. Generally, materials with a regular arrangement of atoms and molecules tend to be more transparent.
What are the key factors that affect a material's transparency?
The key factors that affect a material's transparency include its chemical composition, thickness, and surface roughness. Additionally, the wavelength and intensity of the incident light also play a role in determining a material's transparency.
Can all materials be made transparent to light?
No, not all materials can be made transparent to light. A material's atomic and molecular structure must be arranged in a specific way for it to allow light to pass through without significant scattering or absorption. For example, materials such as metals and wood are not transparent to visible light due to their dense and irregular structures.
How can we make materials more transparent to light?
Materials can be made more transparent to light by altering their molecular structure through processes such as polishing, etching, or doping with certain substances. Additionally, using coatings or layers with different refractive indices can also improve a material's transparency by reducing light scattering and reflection.
9K
