What does jounce help us to do in physics?
  • I
  • Thread starter Physics4Eva
  • Tags
    Physics
In summary: So, think of jounce (and higher order derivatives) as something that can be calculated or estimated from applied excitation, and then used to evaluate stress and strain in the mechanism.
Physics4Eva
TL;DR Summary
How is jounce used in physics and does it have any useful applications?
I understand how jounce is the fourth derivative of position vector, but I don't understand is how it is actually used in physics. I know it differentiates jerk, but what does this help physicists to understand? The following is an equation that explains jounce:
{\displaystyle {\vec {s}}={\frac {d\,{\vec {\jmath }}}{dt}}={\frac {d^{2}{\vec {a}}}{dt^{2}}}={\frac {d^{3}{\vec {v}}}{dt^{3}}}={\frac {d^{4}{\vec {r}}}{dt^{4}}}.}
So how exactly is this equation applied to a graph in terms of acceleration and jerk? And what does jounce truly help us to understand other than differentiation?
Thanks guys!
Likes FactChecker
We can differentiate position an infinite number of times. There is no need to stay awake nights thinking of a unique physics principle associated with each.
See http://wearcam.org/absement/Derivatives_of_displacement.htm
derivativeterminologySI unitmeaning
-5absouncem·s5time integral of abserk
-4abserkm·s4time integral of abseleration
-3abselerationm·s³time integral of absity
-2absitym·s²time integral of absement
-1absement (absition)m·stime integral of position
0position (displacement)mposition
1velocitym·s-1rate-of-change of position
2accelerationm·s-2rate of change of velocity
3jerkm·s-3rate of change of acceleration
4jounce (snap)m·s-4rate of change of jerk
5cracklem·s-5rate of change of jounce
6popm·s-6rate of change of crackle
7lockm·s-7rate of change of pop
8dropm·s-8rate of change of lock
  • Haha
Likes sophiecentaur
But there is a definite intuitive meaning all the way up to and including jerk, so I think it is a good question.
Likes Physics4Eva
I think that is abserk. :devil: :wink:
Likes Vanadium 50 and PhanthomJay
"Definite intuitive" is an oxymoron.
  • Love
  • Haha
Likes Swamp Thing, anorlunda and FactChecker
There's a direct observable related to acceleration, which is how hard you are pushed into your seat or the wall or whatever. Derivatives of acceleration just tell you how it is changing. That it changes is interesting (have you ever tried to stand on a train or bus when the acceleration is changing?), but I'm not sure that higher derivatives are particularly physically significant. They quantify how fast you have to react to changes in acceleration, I suppose, but that's more of an engineering interest than a physics one.
Likes Physics4Eva
I would like to nominate "occupy" as an alternative to "abasement" from the table above.
I occupied the hotel room at x1,y1 for one day. It cost me $100.
I occupied the apartment at x2y2 for a month. It cost me $2000
I occupied a campsite on the island for a week. It was free.
Follow these GPS waypoints and you'll occupy the Appalachian Trail from end to end.
That suggests hike (as in rent hike) instead of "absity."
@Physics4Eva , I apologize for making light of your question. It's Saturday morning.
This quantity, jounce, is better known in the area of cam design as snap. There are some cam designers who think it is important (usually meaning to insist on continuity in snap), while others say it does not matter. The folks I work with in cam design are of the latter school, and say it really does not matter. They do insist on continuity in the first 3 derivatives.
Thanks guys very helpful!:wink:
Cam shafts utilise higher derivatives of position. If you think about a valve in an ordinary internal combustion engine, as the valve changes direction at the top (or bottom) of the cycle the acceleration of the valve is changing. Higher derivatives are also involved as the whole shape of the cam determines an acceleration profile to ensure maximum area under the valve with the least stresses.
Also worth mentioning is that absition is the integral in a PID controller.
Cheers
Likes Physics4Eva
I think you'll find the table says "absement".
Personally, though, I think abasement would have been way more interesting.
But this whole discussion reminds me of that funny-collective-nouns thing. What would be a nice name for a collection of derivatives?
Likes Physics4Eva
"A body experiences a crackle of 2.718 yottameters per attosecond to the fifth power"
<** Cackle! **>
But to address the OP, here's how I see it. Terms like jounce are more relevant to applied physics or engineering. A mechanical system can easily have a frequency response that amplifies higher frequencies much more than lower ones, so that certain parts of the mechanism vibrate a lot more than the applied displacement if that displacement is rapid.
Mathematically, boosting higher frequencies is very much akin to differentiation. And if the system is complex (higher order) then higher derivatives can be generated / amplified.
The "jounce" in the applied stimulus is roughly a measure of how much higher frequency energy is present (especially in a transient) as opposed to lower frequencies, which in turn gives a qualitative indication of how much amplification-related stresses and strains would then be generated.
Likes Physics4Eva
This quest for words that mean absolutely nothing in reality should really be beneath this site.
Look at the example from Swamp Thing. Does that say anything meaningful to anyone? The only place I have ever seen any of these terms arise in in the area of cam design, and area where I still do some work. Most of these terms would mean nothing at all to a cam designer.
If you subject a structure to varying acceleration (every car that was ever designed) then the variation with time of distortion of the components will depend on the Jerk.
It's how we manage to get sticky nuts and bolts apart with a bit of brute (jerk) force.
Likes Physics4Eva and FactChecker
LOL, I tried again and again to override the spell checker. In the end, the spell checker won and I lost. :-)
  • Haha
  • Love
If you really want to communicate, it is far more clear to refer to the 3rd, 4th, 5th, ... derivative of displacement. If on the other hand, the appearance of erudition is the goal, then these strange terms are hard to beat.
I've no clue what all these derivatives should do in physics except trouble ;-)). The only example, where ##\dot{a}## occurs is in the infamous (still not satisfactorily solved) radiation-reaction problem in the connection with classical point particles and electromagnetism. It's only cured in an ad-hoc way by eliminating this ##\dot{a}## term again by eliminating it, using the Landau-Lifshitz version of the Abraham-Lorentz-Dirac equation.
  • Haha
Likes anorlunda and Physics4Eva
Related to What does jounce help us to do in physics?
1. What is jounce in physics?
Jounce, also known as snap or jerk, is the fourth derivative of an object's position with respect to time. It measures the rate of change of an object's acceleration over time.
2. How is jounce related to acceleration?
Jounce is related to acceleration as it is the rate of change of acceleration over time. It can be thought of as the "jerkiness" of an object's motion. A higher jounce value indicates a more abrupt change in acceleration, while a lower jounce value indicates a smoother change in acceleration.
3. Why is jounce important in physics?
Jounce is important in physics because it helps us to understand the dynamics of an object's motion. It allows us to analyze the smoothness or abruptness of an object's acceleration, which can be useful in areas such as engineering, robotics, and transportation.
4. How is jounce measured in physics?
Jounce is measured in units of meters per second cubed (m/s^3) in the SI system. It can also be measured in feet per second cubed (ft/s^3) in the imperial system. Jounce can be calculated by taking the fourth derivative of an object's position with respect to time.
5. What are some real-life examples of jounce?
Jounce can be observed in everyday life, such as when a car accelerates quickly from a stoplight or when a roller coaster makes a sharp turn. It is also important in sports, such as when a baseball player swings a bat or a gymnast performs a routine with sudden changes in acceleration. In engineering, jounce is considered when designing vehicles or machinery to ensure smooth and safe operation.
  • Classical Physics
40K
  • Classical Physics
  • Classical Physics
  • Classical Physics
