What does ∏ mean and how can i use it?
  • Thread starter Vacrin
  • Tags
    Mean
In summary, the conversation discusses the concept of an infinite product, which is similar to a summation but involves multiplication. The notation for an infinite product is represented by the symbol ∏ and can be interpreted as reading a summation but changing the operation to multiplication. An example is provided to illustrate this concept. The conversation also briefly mentions an upside-down version of the symbol, which is used in abstract algebra and is defined as the disjoint union of sets.
Vacrin
ive only studied up to calculus 2, and have never encountered ∏, but from what i believe it means, it is a multiplier. much like summation but instead of adding things together they are times'd together. is this correct? and also can i see a example? thank you :)
Mathematics news on Phys.org
Short answer - you are exactly correct. Read it exactly as you would a summation sign, but change the operation to multiplication.
So, for a really boring example, you had, for example, [itex]\displaystyle\sum\limits_{i=0}^3 i^3[/itex] it would be [itex]0^2 + 1^2 +2^2 + 3^2= 0 + 1 + 9 = 10[/itex]
But if I changed that to [itex]\prod_{i=0}^3i^2[/itex] it would be [itex](0^2)(1^2)(2^2)(3^2)=0[/itex]
Probably less boring if I didn't make it start from zero, but you get he idea. It's a very different answer! (Also note that the formatting is usually the same, with the i=0 and the 3 above and below the sign respectively. For some reason it didn't format that way here. But generally the notation is very similar.
-Dave K
That's because you used inline math mode for one, display mode for the other.
Display mode:
[tex]\prod_{i=0}^3 i^2[/tex]
[tex]\sum_{i=0}^3 i^2[/tex]
Inline: [itex]\prod_{i=0}^3 i^2[/itex] versus [itex]\sum_{i=0}^3 i^2[/itex]
Thanks DH
Thanks guys :)
isnt there also a upside down one of ∏ these? is that the exact opposite? meaning that it is always division instead of multiplication?
I don't think I've ever seen an upside down Pi, but maybe you mean
[tex]\bigcup[/tex]
which is from set theory and has nothing to do with the product symbol.
There is the symbol ##\coprod##. But it is used in category theory and abstract algebra. It has nothing to do with the symbol ##\prod## as used in this thread.
I am familiar (intimately so) with upside-down cake. But this is the first time I'm hearing of upside-down pi. :biggrin:
http://instantrimshot.com/
How does that symbol work? I'm very curious to find out. It probably won't make any sense seeing as how I've never studied abstract algebra
In some sense, it is the "dual" of the product ##\prod##. It is defined as such in category theory. The general definition probably won't make sense to you. But if you know sets, then we can define it as the disjoint union. That is, we define
[tex]\coprod_{i\in I} A_i = \bigcup_{i\in I}( A_i\times \{i\} )[/tex]
Informally, we just take the union of the sets ##A_i##, but we force them to be disjoint by taking the cartesian product with ##\{i\}##.
I wish that made more sense, I recognise one symble, the U, but I'm not sure how to approach the A, and tridant thingy, as well as {i}, but the brackets, bring up a familiar idea such as {a,b,c}
What makes them disjoint? Is that because each A sub i set is mapped to a different i?
FAQ: What does ∏ mean and how can i use it?
What does ∏ mean?
The symbol ∏, also known as pi, is a mathematical constant that represents the ratio of a circle's circumference to its diameter. It is approximately equal to 3.14, but has an infinite number of decimal places.
What is the significance of ∏?
∏ is a fundamental constant in mathematics and is used in many mathematical and scientific calculations. It has applications in geometry, trigonometry, calculus, and more.
How can I use ∏ in calculations?
∏ can be used in various mathematical operations, such as finding the area or circumference of a circle, calculating the volume of a sphere, and solving trigonometric equations. It can also be used in statistics, probability, and other fields of science.
What is the difference between ∏ and π?
∏ and π both represent the same mathematical constant, but they are used in different contexts. In general, ∏ is used in mathematical expressions and equations, while π is used in written or verbal communication.
Are there any real-life applications of ∏?
∏ has numerous real-world applications, such as in engineering, architecture, and physics. It is also used in computer science, specifically in algorithms and coding. Additionally, ∏ has cultural significance and is celebrated on Pi Day (March 14th) by math enthusiasts around the world.
