What does negative potential energy mean?
In summary, when discussing potential energy in the context of lifting a box, the negative sign denotes that the potential energy is negative, but it does not indicate a loss of energy. The choice of reference level for potential energy is arbitrary and can be chosen to be anywhere, but the difference in potential energy between two points remains the same regardless of the reference level. Energy is a scalar quantity and does not have direction. In the case of nearby atoms, the potential energy can become positive if the atoms are too close together. In the equation W = Wnc + -mgh, the negative sign is not subtracting away energy, but rather indicating that the work done by gravity is in the opposite direction of the displacement.
Remain
In the case of lifting a box, I know potential energy is negative because negative work is done by gravity. What does the negative part of -PE denote? Does it denote the direction of the energy or does it mean that energy is being lost? But how is energy being lost if the box gains more gravitational potential energy the higher it's lifted? So what does negative potential energy mean?
Nothing gets lost. If the potential energy increases it is less negative than before.
It means that the potential energy is negative. What else?
The only thing the minus sign in front of PE means is that you've chosen the reference level of 0 PE to be somewhere higher in the gravitational well.
The 0 PE level is arbitrary. You can choose any convention you like.
If you choose 0 to coincide with the surface of the Earth, then any object above it will have positive PE, and any object below the surface will have negative PE.
If you choose 0 to coincide with infinite distance from the source of the gravitational field, then all objects closer than infinity will have negative PE.
However, in both cases (and in any other case) the difference between PE at some two points in the gravitational field will be the same - it's independent of the convention you pick, and that's what makes it meaningful. That difference is the amount of work needed in order to lift an object, or the amount of energy released when it falls.
Energy is not a vector. It is a scalar - it doesn't have direction.
Likes Kaushik, Dale and (deleted member)
A good reason for choosing an arbitrary reference as 'Infinity' is that it's the same for anyone, anywhere in the Universe (at least, in a classical mechanical sense). The familiar model of the rubber sheet with masses sitting on it, to represent a solar system works well and we can all picture an observer at the outer rim (approximating to infinity), with everything 'below' that potential level. The forces are always attractive.
However, if you consider the potential energy situation existing between nearby atoms, the spacing between the atoms is governed by where the Potential Energy is at a minimum. Closer than this and the forces become repulsive and the Potential energy becomes Positive. See this wikipedia link. The mean spacing between atoms will end up at value where the Kinetic Energy of Vibration balances the mean Potential Energy (not the minimum of the curve).
This diagram appears in the link.
Likes Remain
Thanks guys! But in the equation W = Wnc + -mgh, aren't you kind of like subtracting away energy or something?
FAQ: What does negative potential energy mean?
What is potential energy?
Potential energy is a form of energy that is stored within an object or system. It represents the potential for that object or system to do work.
How is potential energy different from kinetic energy?
Potential energy and kinetic energy are both forms of energy, but they differ in that potential energy is stored energy while kinetic energy is the energy of motion. Potential energy can be converted into kinetic energy and vice versa.
What does it mean for potential energy to be negative?
Negative potential energy refers to a situation where an object or system has less potential energy than a reference point. This usually means that the object or system is at a lower height or position than the reference point.
Can potential energy ever be negative?
Yes, potential energy can be negative. This typically occurs when the reference point for measuring potential energy is chosen at a higher point than the object or system's current position. This is often the case when dealing with gravitational potential energy.
How is negative potential energy related to work?
Negative potential energy is related to work in that it represents the work that must be done to bring an object or system from a lower height or position to a higher one. This is because the object or system has negative potential energy and needs to gain energy in order to reach the reference point.
