A What does Rovelli mean with "oriented and ordered graph"?
Heidi
Hi Pfs
Rovelli writes this in his book (Qunatum Gravity) about spin networks:
Given an oriented and ordered graph there is a finite disgrete group of maps that change its order or orientation and that can be obtained as a diffeomorphism.
A link is equipped the source and target functions. this give the orientation.
But what is the order he is talking about.
the paragraph is the 6.4 (Diff invariance)
thanks
You have to label the links first, as ##l_1, l_2, \dots## say, before you can assign a colouring ##j_1 , j_2 , \dots##. It is this labelling of the links that is the ordering, I think. With some graphs there are diffeomorphisms that simply swap the links around and hence change the ordering.
Likes Fractal matter
yes we can do like that to color the links but it is not necessary to have oriented ordered links.
The Penrose's diagrams were the ancestors of the spin networks.
they were trivalent with no explicit intertwiners. the links were not oriented and each link was coloured by a number (not a representation)
So we had a numerical function on a graph without necessary ordering:
to each pair of connected node we assign a number.
Rovelli writes later that if changing the order correspond to swap the variables, changing the orientation leads to replace a variable by its inverse.
If in an oriented loop the holonomy gives a matrix, changing the orientation gives the inverse matrix.
I think, ordering means specifying the predecessor and successor to each node of the graph.
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
In LQG and LQC there are solutions called "black to white transition". I'll add some references: (Rovelli)https://arxiv.org/abs/1905.07251 (Rovelli)https://arxiv.org/abs/2302.03872 (Rovelli)https://arxiv.org/abs/1803.06330 (Rovelli)https://arxiv.org/pdf/1802.04264 (Rovelli)https://arxiv.org/abs/2108.12823 https://arxiv.org/abs/2304.02691 https://arxiv.org/abs/2110.07589 https://arxiv.org/abs/2009.01788 https://arxiv.org/abs/1911.12646 https://arxiv.org/abs/1801.03027...
Hello everyone, I am seeking to better understand the conceptual foundations and potential consequences of "Two-Time Physics" (2T-physics), as developed by Itzhak Bars and others. My interest was sparked by a recent paper that attempts to explain anomalous results in particle physics (apparent superluminal propagation of virtual photons) within the framework of 2T-physics: Paper: https://arxiv.org/abs/2408.02696 Key quote from the abstract: *"...the problem... can be solved naturally...
