MHB What Does the -1 Index Mean in the Abbreviation km h^-1?
  • Thread starter Thread starter Simonio
    Index
The abbreviation km h^-1 represents kilometers per hour, indicating speed. The -1 index signifies the multiplicative inverse, meaning it can be interpreted as "per hour." This notation is equivalent to km/h, a more commonly used format. Additionally, tips for using LaTeX in expressing units include enclosing them within the \text{} command and using curly braces for multi-character exponents. Understanding these conventions enhances clarity in mathematical expressions.
Simonio
I'm looking at a question that refers to kilometres per hour and uses the abbreviation\(km h^-1\)
It looks like a -1 index -could someone [point out to me what this means (I'm only just starting to get back into maths!).
Thanks
Mathematics news on Phys.org
You are probably referring to:
$\text{kmh}^{-1}$
which means the same thing as km/h, that is to say: "kilometers per hour".
The superscript "${}^{-1}$" typically means "inverse", in this case "multiplicative inverse", or in more common language, "reciprocal", that is to say:
$h^{-1} \stackrel{\text{def}}{=} \dfrac{1}{h}$
Thanks
Just a couple of $\LaTeX$ tips...
a) If you want to express units of measure, enclose them within the \text{} command so that they are not italicized like variables.
b) If an exponent has more than 1 character, enclose it within curly braces.
Thus, you could use the code:
\text{kmh}^{-1}
to get:
$$\text{kmh}^{-1}$$
Another tip: If you see a $\LaTeX$ expression and you would like to quickly see how it is done, this is, what code was used, right-click on the expression, and from the pop-up menu choose Show Math As ► TeX Commands, and a small pop-up window will contain the $\LaTeX$ code used to produce the result. You can then copy-paste the code and modify it for your own use in a post if you like.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
