What does the magnetic moment of a particle depend on?
In summary, the magnetic moment of a quantum object is determined by its angular momentum and mass, with a more complex relationship for similar particles and nuclei. The magnetic moment is not dependent on charge and is not a free parameter, as it can be accurately predicted through quantum field theory.
joegibs
47
Every magnetic object has a magnetic moment. From electrons to molecules, to even planets.
But my question is, what determines how much of a magnetic moment a quantum object has? I'm not sure if "how much" is the right word for it. What determines the "quantity" of a magnetic moment of a particle? Still not sure if quantity is the right word. But anyway, does the magnetic moment of a quantum particle depend on mass, charge, ect? Or is it just an intrinsic property that a particle has, and is not dependent on anything?
It's not a free parameter. The gyromagnetic ratio for an electron has been accurately predicted to 12 decimal places or so, and this is one of the successes of quantum field theory. Sorry, I don't know much more about it.
For elementary particles, the magnetic momentum depends on the angular momentum and the mass, though not necessarily in a simple way. For similar particles the magnetic moment increases with the angular momentum*. For particles of the same spin, the magnetic moment is roughly inversely proportional to the mass. (Both the proton and the electron are spin-1/2 particles; the proton is about 2000 times the more massive, while its magnetic moment is about 700 times smaller.) Charge isn't a good indicator. The neutron is an uncharged particle but is has a respectable magnetic moment--about 70% of that of the proton--which can be interpreted as due to a distribution of charge within the neutron).
*Edit. This is simplistic. The magnetic moments of nuclei are roughly of the same order of magnitude but their actual dependence on spin from element to element looks pretty random to the uninformed eye. Nuclei in this respect are not elementary particles and their internal structure causes the relation between angular momentum and magnetic moment to be quite complex.
Related to What does the magnetic moment of a particle depend on?
1. What is the definition of magnetic moment?
The magnetic moment of a particle is a measure of the strength and direction of its magnetic field. It is a vector quantity, meaning it has both magnitude and direction.
2. What factors affect the magnetic moment of a particle?
The magnetic moment of a particle depends on its charge, mass, and spin. These properties determine the strength and direction of the particle's magnetic field.
3. How is the magnetic moment of a particle measured?
The magnetic moment of a particle can be measured using a variety of techniques, such as nuclear magnetic resonance (NMR) or electron paramagnetic resonance (EPR). These methods use magnetic fields to interact with the particle's magnetic moment, allowing for its measurement.
4. Does the environment of a particle affect its magnetic moment?
Yes, the magnetic moment of a particle can be affected by the surrounding environment. For example, the presence of other particles or external magnetic fields can influence the direction and strength of a particle's magnetic moment.
5. How does the magnetic moment of a particle relate to its behavior in a magnetic field?
The magnetic moment of a particle determines how it will behave in a magnetic field. A particle with a larger magnetic moment will experience a stronger force in a magnetic field, while a particle with a smaller magnetic moment will experience a weaker force. The direction of the particle's magnetic moment also affects its behavior in a magnetic field, as it will align itself with the external magnetic field.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
