find_the_fun
- 148
For example my textbook reads if G(V, E) is a pseudograph then \(\displaystyle \sum\limits_{v \in V} deg(v) = 2|E|\)
alane1994 said:This will sound ridiculous but I have seen that mean "absolute value"?
\(\left|-3\right|=3\)
But I have hear that referred to as "magnitude" as well. I am just spitballing here; if I had to go with anyone response, I would go with Bacterius.
EDIT: After re-reading Bacterius' post several times, mine almost looks childish... (Speechless)
The notation | | is called absolute value and it represents the distance of a number from 0 on the number line. It is always positive regardless of the sign of the number.
Absolute value is used to indicate the magnitude or size of a number without considering its sign. It is helpful when dealing with distance, temperature, or any other quantities that can only have positive values.
The absolute value of a number is calculated by removing the negative sign, if present, and keeping the positive value. For example, the absolute value of -5 is 5, and the absolute value of 5 is also 5.
When absolute value is applied to a complex number, it calculates the distance of the number from the origin on the complex plane. The result is always a real number, and it represents the magnitude of the complex number.
Other notations for absolute value include the double vertical bars ||, the pair of straight lines | |, and the pair of brackets [ ]. They all indicate the same concept of absolute value and can be used interchangeably.
