What does the union of an infinite sequence of intervals converge to?
  • MHB
  • Thread starter Guest2
  • Tags
    Union
In summary, the intersection of the given intervals is just the number 2.In summary, the meaning of $\displaystyle \bigcup_{n=1}^{\infty} [5^{-n}, n]$ is an interval that includes all values from $0$ to $\infty$, with the lower bound being $0$ and the upper bound never quite reaching $0$. The same method can be applied to find the meaning of $\displaystyle \bigcap_{n=1}^{\infty} [1+\frac{1}{n}, 1+n]$, which results in the number $2$ being the only value in the intersection.
Guest2
193
What's the meaning of [tex]\displaystyle \bigcup_{n=1}^{\infty} [5^{-n}, n][/tex]?
Hi Guest! (Smile)
It's:
$$\bigcup_{n=1}^{\infty} [5^{-n}, n]
=[5^{-1},1] \cup [5^{-2}, 2] \cup [5^{-3}, 3] \cup \dots = (0, \infty)$$
I like Serena said:
Hi Guest! Welcome to MHB! (Smile)
It's:
Hi, thanks for replying.
How did you get $(0, \infty)$?
Were getting an interval with a lower bound that is the result of $5^{-1},5^{-2},5^{-3},...$.
It never quite reaches $0$, but it comes closer than any positive value.
Therefore the lower bound of the interval is $0$ while excluding $0$ itself.
The same holds for the upper bound.
Thank you.
Could we apply the same method to $\bigcap_{n=1}^{\infty} [1+\frac{1}{n}, 1+n]
$? The answer is $\left\{2\right\}$, but I don't know how to get it.
Guest said:
Thank you.
Yes. The same method applies.
Where are you stuck? (Wondering)
As n goes to infinity the lower bound $1+1/n \to 1$ and the upper bound $n+1 \to \infty$ so I get $[1, \infty)$ which is wrong.
Hi Guest,
Here's a way to show that
$$\bigcap_{n = 1}^\infty \left[1 + \frac{1}{n},1 + n\right] = \{2\}.$$
Let $A$ represent the set on the left hand side of the above equation. If $x\in A$, then
$$1 + \frac{1}{n} \le x \le 1 + n\quad \text{for all} \quad n\in \Bbb N.$$
In particular, setting $n = 1$, we get
$$2 \le x \le 2.$$
This means that $x = 2$. Hence $A \subseteq \{2\}$. On the other hand, we know that if $n\in \Bbb N$, $\frac{1}{n} \le 1 \le n$, which implies
$$1 + \frac{1}{n} \le 2 \le 1 + n.$$
Since $n$ was an arbitrary natural number, then $2 \in A$. Therefore, $A = \{2\}$.
FAQ: What does the union of an infinite sequence of intervals converge to?
What is the definition of union?
A union is a state of being united or joined together, often for a common purpose or goal.
What is the significance of union in science?
In science, union refers to the combining or merging of separate elements or concepts to create a new and more comprehensive understanding or theory.
How does the concept of union apply to biology?
In biology, union is often used to describe the fusion of cells or organisms, such as during fertilization or the formation of multicellular organisms.
Can union also refer to the coming together of ideas or beliefs?
Yes, union can also apply to the unification of ideas or beliefs, such as in the formation of social or political movements.
Is there a difference between union and unity?
While both terms refer to the state of being joined or united, union implies a more intentional or deliberate coming together, while unity can also occur naturally or by chance.
