What does this mean? (equation for viscous flows)
In summary, the conversation discusses the interpretation of an equation related to viscous flows, specifically the significance of the "funny O" symbol. It is explained that this symbol represents the order of magnitude of a function and can imply proportionality, but is not always the same. The conversation also touches upon the concept of Reynolds number and how it relates to the transition from viscous to turbulent flow.
vktsn0303
30
While reading a textbook on viscous flows, I came across the following interpretation of an equation:
where, v is the vertical component of the free stream velocity and y is the vertical distance from the surface of a solid and Re is the reynolds number.
Can someone please help me understand what this interpretation means?
Thanks in advance
The funny O means 'is of the order of'
My interpretation would be: if the reynolds number quadruples, v and y become approximately half as big
Often the funny O is used instead of 'is proportional to' (##\propto##) if the reasoning aims to justify ignoring certain terms. But I don't know if that is true in your context.
The order symbol expresses a concept similar to proportionality but not quite the same. It's a statement of how one function grows relative to another. In this case, ##v## and ##y## grow as ##Re^{-1/2}##. In other words, ##v## and ##y## are bounded by ##Re^{-1/2}## multiplied by some factor as they grow. This can imply proportionality but does not necessarily. Essentially, proportionality is a stronger constraint.
The "O" is called "big O notation". It means "on the order of magnitude of" Your average student body size for a college campus might be O(10^4) (between 10,000 and 99,999 students), but your average classroom size might be O(10^1) (10 to 99), for example.
Likes Randy Beikmann
This is called viscous flow.In this when you go upward from a fixed surface the velocity of the layer of liquid increases.At the bottom layer velocity would be zero and at top velocity of layer would be maximum.Reynold number shows that upto a specific value of Reynold number flow would be viscous and beyond that number flow would become transit and the turbulent flow.see the images below.
imgaes2
Related to What does this mean? (equation for viscous flows)
1. What is the equation for viscous flows?
The equation for viscous flows is known as the Navier-Stokes equation. It is a set of partial differential equations that describe the motion of fluid substances, including viscous flow. It takes into account factors such as viscosity, density, and pressure gradients.
2. What does the equation for viscous flows represent?
The Navier-Stokes equation represents the conservation of momentum for a fluid. It describes how the velocity of a fluid changes over time, taking into account the forces acting on the fluid, such as viscosity and pressure.
3. How is the equation for viscous flows derived?
The Navier-Stokes equation is derived from the fundamental laws of physics, specifically the conservation of mass, momentum, and energy. It is a mathematical representation of these physical principles and is often used in fluid mechanics to analyze and predict the behavior of viscous flows.
4. What are the assumptions made in the equation for viscous flows?
The Navier-Stokes equation makes several assumptions about the fluid being analyzed, including that it is incompressible, Newtonian (exhibits constant viscosity), and has no external forces acting on it. These assumptions allow for a simplified equation that can still accurately describe the behavior of viscous flows.
5. Can the equation for viscous flows be solved analytically?
In most cases, the Navier-Stokes equation cannot be solved analytically and requires numerical methods to find a solution. This is because the equation is nonlinear and involves complex terms such as velocity gradients. However, in some simplified cases, analytical solutions can be found, such as for laminar flow in a pipe.
  • Aerospace Engineering
  • Classical Physics
  • Mechanical Engineering
