What does this two momentum transform look like?
In summary, this transformation is a canonical transformation, which is a transformation that preserves the geometric properties of the vectors.
rtransformation
qi is the cartesian coordinate, and Qi is the Generalized coordinate, why the momentum under the two coordinates have this transformation way:
pi=∑Pj(∂Qj/∂qj)
pi and Pi are corresponding momentum under the two coordinate respectively.
Hi rtransformation. Welcome to the forum.
This is how vectors transform under a coordinate transformation. You need to study vector transformations. For example, rotations, changes to spherical or cylindrical coordinates, etc.
So the reason that momentum transforms this way is that it is a vector.
Thank you! I really need to study some basic knowledge now...Thank you again.
actually, I didn't find the relation between the vector transformation and my question, could you please be more specific and help me solve this problem?Thank you very much.
Is this transformation a contact transformation?
I have no idea if it is a "contact transformation." I looked up "contact transformation."
https://en.wikipedia.org/wiki/Contact_geometry
It was fun, but seemed to be somewhat far afield from your question.
What sort of answer would satisfy you? This is how a vector transforms under a coordinate change. It is part of the definition of a vector.
I just want to know how I can get this result through derivation.:frown:
I would suggest looking at a graduate level classical mechanics book in a chapter on canonical transformations.
Thank you, I now get it.
I'm not sure I do though. Would you mind posting your explanation for the curious reader?
I found it in the Walter Greiner‘s famous classical mechanics book “Classical Mechanics——Systems of Particles and Hamiltonian Dynamics” ,Chapter 19——Canonical Transformation,and what I asked is the point transformation which is discussed in detail in this book.
FAQ: What does this two momentum transform look like?
What is momentum transform?
Momentum transform, also known as Fourier transform, is a mathematical operation that converts a function or signal from its original domain (usually time or space) to a representation in the frequency domain.
How does momentum transform work?
Momentum transform involves decomposing a function or signal into its component frequencies by taking the integral over time or space. This results in a representation of the function in the frequency domain, where each frequency component is assigned a magnitude and phase.
Why is momentum transform important?
Momentum transform is important in many fields, including physics, engineering, and mathematics. It allows us to analyze signals and functions in terms of their frequency components, which can provide valuable insights and allow for more efficient calculations.
What does momentum transform look like graphically?
Graphically, momentum transform takes a function or signal and converts it from a time or space domain representation to a frequency domain representation. This is typically shown as a plot of the magnitude and phase of the frequency components.
How is momentum transform used in science?
Momentum transform has numerous applications in science, including signal processing, image reconstruction, and solving differential equations. It is also used in fields such as optics, acoustics, and quantum mechanics to study the behavior of waves and particles.
