Learnphysics
- 92
Capacitor concept problem
Capacitors.
I have a general idea of how they work:
They don't allow charges to pass through, so the charges build up on one plate and cause a voltage across the plates.. until the Capacitor has the same voltage as the greatest voltage in the circuit, then when that voltage is turned off the capacitor now has the highest voltage in the circuit and so the charge flows out of it, around the circuit and back to it's other plate.
The equations associated with this are q=C*V, and i=C*(dv/dt).
My question is this, what does the V stand for in the first equation? Voltage across what? voltage where?
I had an idea that the dv/dt refers to the difference in voltage across the plates at anyone point in time. ANd that made a lot of sense to me. (eg, when there's a high difference across the plates current flows, when there's no difference, no current flows).
But I'm beginning to suspect thinking of the dv/dt as a simple DIFFERENCE in voltage is going to cause problems, and i need to begin considering it as a infinitesimal difference in voltage, over an infinitesimal difference in time?
Or do i even need to do this, can i continue thinking about it as just a difference in voltage.
How does dv/dt differ from the "V" in q=C*V.
Also: wikipedia says that charge cannot flow through a capacitor, it simple behaves like a membrane in a pipe. I know that while the capacitor is charging, it can be thought of as electrons are accumulating on one of the plates. But if the electrons are accumulating on one of the plates, how can current be flowing through the entire circuit? Current must only be flowing from the voltage source to one plate of the capacitor.
Is this correct?
Capacitors.
Is this correct?
