kmarinas86
- 979
- 1
The "v" of the Lorentz Force
If I have a rotating magnetic dipole that is rotating at an accelerated rate, then it is clear that the "v" of the "B" increases around the axis of that dipole's rotation. In addition, this should affect the "v" of the "q" affected by the "B", but the force induced on that q exists at a right angle. Isn't "v" of the Lorentz Force much different though? Is this "v" really the relative velocity of source charge of the magnetic field and the charge being affected (i.e. in that it does not rotate with the "B" field)? If this were not the case, then "v" could easily exceed the speed of light, which makes no sense of course. If instead, the former were the case, then different source charges would have different contributing B's as well as different contributing v's. But if those v's have absolutely nothing to do with B-field lines cutting through charges at "v", then at this stage should we reject the notion of B-field lines cutting charges at "v". If we should, how should we look at it then? What is "v" when distance from source of the magnetism * angular velocity of magnetic dipole > c? Can the velocity addition formula be used here, and how (if applicable)?
