What does 'velocity is derivative of distance' mean?
In summary, Velocity is a vector, with a magnitude that is a scalar and is called Speed. Velocity has components in three dimensions, and it can be visualized as a vector in space or spacetime.
Zach Forney
What does v equals dx/dt mean? I interpret v as: the limiting value as a vanishingly small value for time t (dt) goes to 0. Or lim as dt-->0 of dx/dt.
I believe that would be instantaneous velocity. In general, if the equation for position vs time is X= T2 +B, where B is a constant and T is the variable for time, then the equation for the velocity is the derivative: V = 2T
Thank you for the reply
Velocity is a vector, defined as the derivative with respect to time of another vector: displacement, r, (from a given point). The idea is that we take a time interval, [itex]\Delta t[/itex], centred on the particular time instant, t, that we're interested in, and consider [itex]\Delta \mathbf r[/itex], the change in r over the time interval [itex]\Delta t[/itex]. The mean velocity over [itex]\Delta t[/itex] is then defined by
[tex] \mathbf{v_{mean}} = \frac{\Delta \mathbf{v}}{\Delta t}.[/tex]
The velocity, v, at time t is defined as the limit of the mean velocity over [itex]\Delta t[/itex], as [itex]\Delta t[/itex] tends to zero.
In plain English.. The slope of the graph of distance vs time.
Fine if v is the component of velocity in a given direction, but if v is velocity in its general, vector, sense, it has components in three dimensions, so it's hard to see what single graph it would be the slope of.
Hmmm. Perhaps it would be the derivative of the magnitude of the displacement wrt time, which you would then multiply by the displacement's unit vector?
Absolutely not - this would imply that velocity is always directed exactly away from the origin.
If you have components of ##\vec v##, then those components are slopes in the corresponding position-coordinate-vs-time graphs. In three-dimensions, you have three such graphs.
If you want to visualize ##\vec v## vectorially in a single "graph", you can visualize it in space (or spacetime) as certain tangent-vectors to the trajectory (or worldline).
I assumed Drakkith intended to say: plot distance along path against time, so slope of graph gives speed, then multiply by instantaneous unit vector in the direction the body is moving (that is by the magnitude of the velocity vector).
It is indeed very important to first make yourself clear that velocity is a vector (its magnitude is a scalar and called speed; English is great in being precise enough to distinguish these concepts clearly). The use of vectors is of great help in physics from day 1 on anyway. So it's good to learn about it.
One first has to start with a space-time model. In the introductory physics course you start with the (apparently) most simple successful space-time model, the Newton-Galilei space-time. According to this model, space and time are independent of any physical processes, and any observer describes space as a three-dimensional Euclidean space of points and time as an orientied one-dimensional continuum. You can visualize this space-time as a straight line (depicting the real numbers in the usual way) along which in each point there is a three-dimensional Euclidean space.
You can discribe the three-dimensional Euclidean space by arbitrarily singling out one point ("the origin"). Then each point can be addressed by a vector, i.e., an arrow pointing from the origin to that point, the position vector ##\vec{x}##. The origin itself is given by the null vector. Using three rigid rods of unit length, perpendicular to each other, giving three vectors ##\vec{e}_j##, you have a Cartesian basis, and you can describe each point by the three components of the position ##\vec{x}=x^j \vec{e}_j##, where ##x^j## are real numbers, and ##j## runs from 1 to 3. If in an equation 2 indices (one upper, one lower) are the same, you understand that one takes the sum of the corresponding three expressions:
$$\vec{x}=x^j \vec{e}_j \equiv \sum_{j=1}^3 x^j \vec{e}_j.$$
Now the most simple system is a "point particle", which is a small macroscpic body (small compared to the typical scales of its motion; e.g., in astronomy at first approximation you can consider the Sun and the Earth as point particles orbiting each other due to gravitational interaction). It's position is given as a function of time ##\vec{x}=\vec{x}(t)##.
Then the average velocity between two times ##t_1=t## and ##t_2=t+\Delta t## is defined as
$$\langle \vec{v} \rangle_{\Delta t}=\frac{\vec{x}(t+\Delta t)-\vec{x}(t)}{\Delta t}.$$
The meaning is immideately clear: The difference of two vectors in the numerator gives the arrow (displacement) of the body from its initial position ##\vec{x}(t)## to its final position ##\vec{x}(t+\Delta t)##, and dividing by the time ##\Delta t## it took to make this change of position, gives you a precise measure of how fast the particle is going and, also pretty important, from where to where it precisely went.
Now you can let ##\Delta t \rightarrow 0##. Then you get the momentaneous velocity, which tells you the direction and magnitude of the change of position during an infinitesimal time interval ##\mathrm{d} t##. This is called a derivative with respect to time, i.e.,
$$\vec{v}(t)=\lim_{\Delta t \rightarrow 0} \frac{\vec{x}(t+\Delta t)-\vec{x}(t)}{\Delta t}=\frac{\mathrm{d}}{\mathrm{d} t} \vec{x}(t)=\dot{\vec{x}}(t).$$
dx/dt is a notation for x'(t), which by definition is equal to ##\lim_{\Delta t\to 0}\frac{\Delta x}{\Delta t}##. So you shouldn't put a "lim" in front of dx/dt.
This is just a comment about the notation dx/dt. Everything else is explained by vanhees71 in the post above this one.
Ah yes, I think I misinterpreted what he was saying - sorry Drakkith!
FAQ: What does 'velocity is derivative of distance' mean?
What is the meaning of "velocity is derivative of distance"?
This phrase refers to the mathematical relationship between velocity and distance. It means that velocity is the rate of change of distance over time, or in other words, how fast an object is moving in a particular direction.
How is velocity related to distance?
Velocity and distance are related by the concept of differentiation in calculus. Velocity is the derivative of distance, meaning it is the slope of the distance-time graph.
What does it mean to take the derivative of distance?
Taking the derivative of distance involves finding the rate of change of distance with respect to time. This allows us to determine the velocity of an object at any given point in time.
Why is the derivative of distance important in science?
The derivative of distance is important because it helps us understand the motion of objects. It allows us to calculate the velocity, acceleration, and other important parameters that describe an object's movement.
Can you give an example of how velocity is the derivative of distance?
Imagine a car traveling at a constant speed of 60 miles per hour. After 1 hour, the car will have traveled a distance of 60 miles. The derivative of this distance is the car's velocity, which is 60 miles per hour. If the car's speed changes, the derivative of distance will also change accordingly.
