What equivalence of vacuum in pressured system is possible?
In summary, if you heat gas inside a sealed container, the pressure increases and some gas escapes through the valve to the outside. The maximum equivalent vacuum that can be obtained is limited by the temperature at which the gas can be heated and by the integrity of the container.
BernieM
281
If I have a volume of gas in a sealed container with a special one way valve in it, and I heat the gas inside the container, the pressure increases and some gas escapes through the valve to the outside. I now have less atoms of gas inside the container, which, when cooled back to the starting temperature will be a partial vacuum. If I continue to heat the gas in the container higher and higher, what is the maximum equivalent vacuum that I could obtain?
Is the limit going to be the maximum temperature I can obtain in the gas? Or some other physical limit? With enough power to create sufficient heat, could I in effect reach a state, for example, of 10 -6 torr, as far as the number of atoms in the volume and at the same time be maintaining an internal pressure equivalent to the pressure outside the container?
So to avoid 'practicalities' of the valve, let's say it works on effusion or in some ideal way that would not let any molecules back into the chamber and that the chamber material and construction is some ideal container that can withstand any temperature and doesn't pass any heat through it's walls to the outside so there is no loss of heat there.
Why don't you just run some calculations on your own using the ideal gas law and see what you come up with?
I wasn't sure it was valid at all temperatures where the atoms become a plasma.
From Wikipedia:
Deviations from ideal behavior of real gases
The equation of state given here applies only to an ideal gas, or as an approximation to a real gas that behaves sufficiently like an ideal gas. There are in fact many different forms of the equation of state. Since the ideal gas law neglects both molecular size and intermolecular attractions, it is most accurate for monatomic gases at high temperatures and low pressures. The neglect of molecular size becomes less important for lower densities, i.e. for larger volumes at lower pressures, because the average distance between adjacent molecules becomes much larger than the molecular size. The relative importance of intermolecular attractions diminishes with increasing thermal kinetic energy, i.e., with increasing temperatures. More detailed equations of state, such as the van der Waals equation, account for deviations from ideality caused by molecular size and intermolecular forces.
So since I was wondering for example how hot I would have to heat the gas to get it to the equivalence of atoms / cubic centimeter to a vacuum of 1e10-6 torr or better, I figured it was going to have to be very very hot (millions of kelvins) and hence my question of what may be the barrier to that that I was not aware of.
From Wikipedia:
Your assessment seems correct. For the pressures you are interested in, the ideal gas law would be adequate. Of course, integrity of the container would be an issue at those kinds of temperatures.
In order for gas to escape, the pressure inside when hot must be greater than the pressure outside which is presumably atmospheric pressure. You should be able to improve on this by venting the container into another that is already below atmospheric pressure. Perhaps have a line of containers each venting into the next one in the chain with valves in between.
That's why I said that the container was an ideal container that could withstand any temperature (though no such critter exists) to avoid complications regarding the container.
The outside of the container would be atmospheric pressure for the purposes of helping answer this question. But if I have a vacuum ultimately outside of the chamber, the inside of the chamber would eventually get to a vacuum also, and no longer exist at atmospheric pressure.
But I'm not yet seeing the answer I am looking for. So let me find another way to get this question posed:
Suppose I build an IEC device (Inertial Electrostatic Confinement), and instead of pumping it down with a vacuum pump, let the arc from my device heat a volume of hydrogen inside the container, which is at atmospheric pressure. Outside is also atmospheric pressure. Ignoring for now the valve and container, as I heat the hydrogen it expands, and gas escapes. The atoms per cubic volume is now reduced so I have the equivalent of a vacuum. Ultimately the internal pressure should always stay at atmospheric pressure and not go to a true vacuum when it's heated up. Only when allowed to cool would it become a vacuum.
I am fairly sure the gas laws would predict for lower pressures, but as the temperature gets extremely high (say 50 million to 200 million kelvins), does the process stop at some point or does the gas law no longer become reliable to calculate the conditions requiring that I use some other formula?
I think it comes down to 'at very high temperatures in millions of kelvinis, at a given non-zero pressure, what is the free mean path between atoms in the plasma'
Is there a limit (other than how hot I can heat the hydrogen, the container or the valve design) and what would those limits be caused by? Would it be a relativistic limit at one point where protons or nucleons are bouncing around at near C, for example?
Related to What equivalence of vacuum in pressured system is possible?
1. What is a vacuum in a pressured system?
A vacuum in a pressured system refers to a space or region within a system where the pressure is significantly lower than the surrounding areas. This can be created artificially by removing particles or gases from the space, or it can occur naturally in high-altitude environments.
2. How is vacuum measured in a pressured system?
Vacuum in a pressured system is typically measured in terms of absolute pressure, which is the total pressure within the system. This can be measured using units such as torr, pascal, or atmospheres. The lower the absolute pressure, the greater the level of vacuum.
3. What is the ideal level of vacuum in a pressured system?
The ideal level of vacuum in a pressured system depends on the specific application and the desired results. In some cases, a higher level of vacuum is needed for optimal performance, while in others a lower level may be sufficient. The appropriate level of vacuum should be determined based on the specific needs of the system.
4. What is the relationship between pressure and vacuum in a pressured system?
In a pressured system, there is an inverse relationship between pressure and vacuum. This means that as pressure decreases, vacuum increases, and vice versa. This relationship is important to understand in order to effectively control and manipulate the vacuum level in a pressured system.
5. What factors influence the creation and maintenance of vacuum in a pressured system?
Several factors can influence the creation and maintenance of vacuum in a pressured system, including the type of equipment used, the level of pressure differential, and the presence of any leaks or contaminants. It is important to carefully consider and control these factors in order to achieve the desired level of vacuum in a pressured system.
  • Mechanical Engineering
  • Mechanics
  • Mechanics
9K
15K
