- #36
- 6,993
- 2,470
The binary pulsar results are compelling
http://relativity.livingreviews.org/Articles/lrr-2006-3/articlesu17.html
pervect said:I agree with Garth that the Pound-Rebka experiment doesn't test all aspects of GR, i.e. it doesn't distinguish GR from all alternate theories. On the other hand, I would say that the experiment does provide direct experimental support for GR, which is what the OP appears to be trying to deny.
Yet the system consists only of bodies orbiting in vacuo. Theories that are conformally equivalent to GR in vacuo, such as http://en.wikipedia.org/wiki/Self_creation_cosmology , also predict the same gravitational radiation flux from binary pulsars.robphy said:The binary pulsar results are compelling
This is proof for a physical theory that is more general than just SR. SR is coordinate-system dependent, and the experimental evidence is not.Meir Achuz said:For SR, I consider the verification of p=mv\gamma thousands of times each day the best proof.
Aether said:This is proof for a physical theory that is more general than just SR.
SR and GGT (aka, Lorentz ether theory) are the same physical theory in different coordinate systems. I refer to this more general physical theory as "Lorentz symmetry"; if anyone else has a better suggestion for a name, then I would like to hear it.clj4 said:What would that theory be?
This shows how SR is only a subset of the physical theory proven by the referenced experiments.What is the relevance of the above statement?Aether said:SR is coordinate-system dependent, and the experimental evidence is not.
Please show a coordinate-system independent formulation of SR.You know perfectly well that there are coordinate independent formulations of SR (as well as coordinate dependent experimental proofs).
I will simulate the addition and subtraction of some sine functions to test your claims in the other thread and then get back to you.Are you still interested in re-running the Gagnon experiment? I offered you the theoretical data...never heard back from you on my offer.
Aether said:SR and GGT (aka, Lorentz ether theory) are the same physical theory in different coordinate systems. I refer to this more general physical theory as "Lorentz symmetry"; if anyone else has a better suggestion for a name, then I would like to hear it.
This is simpy a difference in coordinate-systems, and that's all.clj4 said:Nonsense. SR has no preferred frame, GGT does.Aether said:SR and GGT (aka, Lorentz ether theory) are the same physical theory in different coordinate systems. I refer to this more general physical theory as "Lorentz symmetry"; if anyone else has a better suggestion for a name, then I would like to hear it.
You were supposed to "show a coordinate-system independent formulation of SR", but you didn't do that. Notice how in Sec. 2.2 The Lorentz transformation, the discussion is about "coordinates", and section 2.5 begins "The set of transformations of coordinates in spacetime...".Gladly, here is one of the many:
http://www.physics.sfsu.edu/~lea/courses/grad/705notes-1.PDF
There are litterally hundreds of such formulations taught in colleges.
This belongs in the other thread. Why don't we both delete this discussion from this thread, and move it to the other thread?"Simulate"? How? You don't even have the correct formulas. The stuff that the "sock puppets" wrote is incorrect and you couldn't calculate a valid formula.
"Coordinate-system independent" means that the formulation does not depend on the choice of coordinate system. It does not mean that the formulation eschews the use of coordinates entirely.You were supposed to "show a coordinate-system independent formulation of SR", but you didn't do that. Notice how in Sec. 2.2 The Lorentz transformation, the discussion is about "coordinates", and section 2.5 begins "The set of transformations of coordinates in spacetime...".
This would be a coordinate-system independent formulation of SR?Hurkyl said:"Coordinate-system independent" means that the formulation does not depend on the choice of coordinate system. It does not mean that the formulation eschews the use of coordinates entirely.
That said, it IS easy enough to formulate SR without any reference to coordinates. The simplest I can imagine starts with Euclidean 4-space, postulates the existence of a single "null-cone", and then uses that cone to define a new notion of length and angle, thus arriving at Minowski space. The rest is just elementary calculus.
Not only is coordinate-system independent (which it automatically is, since it's a formulation of SR), but it's done without any reference to coordinates, whatsoever.Aether said:This would be a coordinate-system independent formulation of SR?
Hehe! Of course, I couldn't exactly say "easy enough" in the same breath as that...coalquay404 said:Actually, there are countless elegant and esoteric coordinate-free formulations of SR. My favourite involves
What I am claiming is that SR is empirically equivalent to Generalized Galilean Transform (GGT), aka Lorentz ether theory, and that they are both the same physical theory using different coordinate systems.coalquay404 said:Ergo, anyone who claims that coordinate-free approaches to SR do not exist really doesn't know what they're talking about.
Every formulation of SR is automatically coordinate-system independent?Hurkyl said:Not only is coordinate-system independent (which it automatically is, since it's a formulation of SR), but it's done without any reference to coordinates, whatsoever.
Aether said:What I am claiming is that SR is empirically equivalent to Generalized Galilean Transform (GGT), aka Lorentz ether theory, and that they are both the same physical theory using different coordinate systems.
Do these coordinate-system independent formulations of SR define the one-way speed of light as a constant?
SR is a coordinate-independent theory, therefore any formulation of it will be coordinate-independent.Aether said:Every formulation of SR is automatically coordinate-system independent?
Ah, but 3-velocity is not a physical quantity! The coordinate-free formulations wouldn't say anything at all about 3-velocity, since the very notion of 3-velocity depends on a choice of coordinates (which is one reason why it's called the "coordinate velocity").Aether said:Do these coordinate-system independent formulations of SR define the one-way speed of light as a constant?
I would like to understand this subtlety better.coalquay404 said:There's a subtle but devastating difference between coordinate-independent and coordinate-free. I think that's where your confusion stems from. Special relativity is automatically (indeed, by construction) coordinate-independent, although the original formulation is not coordinate-free.
clj4 insists that the one-way speed of light is measurable in a coordinate-system independent way, and cites http://imaginary_nematode.home.comcast.net/papers/Gagnon_et_al_1988.pdf" paper as proof. GGT is introduced within this paper, and an experiment is described which is supposed to be able to distinguish between GGT and SR. Many other people also think that this is plausible.I'm unaware of what the GGT you speak of is, but your mention of the aether makes my eyes glaze over in resignation.
The Gagnon paper claims to be able to distinguish between GGT and SR, and clj4 believes their claim. I am simply pointing out that SR and GGT are *not* distinguishable by any experiment.What's more, the claim that "they are both the same ... theory using different coordinate systems" sounds, to people who understand the wording, ridiculous. If they are equivalent modulo choice of gauge then your GGT is *not* distinguishable from special relativity and hence should be discarded.
Aether said:clj4 insists that the one-way speed of light is measurable in a coordinate-system independent way,
...and cites http://imaginary_nematode.home.comcast.net/papers/Gagnon_et_al_1988.pdf" paper as proof. GGT is introduced within this paper, and an experiment is described which is supposed to be able to distinguish between GGT and SR. Many other people also think that this is plausible.
I have a lot to learn about many things, but I haven't tried to distort the truth nor have I made willfully false claims. The Gagnon paper is wrong, one or two of the others have some relatively minor flaws, and you are misinterpreting the rest.clj4 said:This is a gross distortion of the truth. What is shown in the 10-12 papers that I have given you is that while aether theories (a la GGT) claim light speed to be anisotropic, all these experiments, conducted by respected physicists and published in peer refereed journals have shown no detection of such light speed anisotropy within the error bars. As such, they show that there is a distinction between "aether" theories and SR.
You have tried repeatedly, on multiple threads to distort the truth and every time you have just proven that you can't even perform some simple calculations. And though, you persist? Why? Do you need a refresher on "Wrong (and wilfully false) claims"?
The above sounds arrogant, considering the fact that in our interaction over the Gagnon paper you have repeatedly shown that you cannot calculate.Aether said:I have a lot to learn about many things, but I haven't tried to distort the truth nor have I made willfully false claims. The Gagnon paper is wrong, one or two of the others have some relatively minor flaws...
Ok, but this is equally true for GGT, aka Lorentz ether theory (LET), right? GGT/LET is a formulation of SR?Hurkyl said:SR is a coordinate-independent theory, therefore any formulation of it will be coordinate-independent.
Most formulations will not be "manifestly" coordinate-independent: they will formulate SR in a way that apparently depends on the choice of coordinate system. But it is then later proven that if we had started with a different coordinate system, we would still arrive at the exact same theory.
The coordinate-free formulation is still SR?Ah, but 3-velocity is not a physical quantity! The coordinate-free formulations wouldn't say anything at all about 3-velocity, since the very notion of 3-velocity depends on a choice of coordinates (which is one reason why it's called the "coordinate velocity").
Right.There are all sorts of coordinate systems you can put on Euclidean space, and you can do Euclidean geometry in any of them. But the Euclidean geometry has a "nicest" class of coordiante systems: the orthonormal ones, right?
Ok. Then GGT/LET is still SR? What then do we call SR when the one-way speed of light is defined as a constant?The same is true in Minowski space: the geometry picks out a "nicest" class of coordinate charts, and those are what we often call the "inertial reference frames". Those do, indeed, have a constant one-way (coordinate) speed of light. But other affine coordinate charts on Minowski space do not have constant one-way speed of light. The curvilinear charts, of course, don't even have light traveling along a coordinate-line!
Doing SR in a "skew" coordinate system does not change it into another theory -- it's still SR. (Just like Euclidean geometry done in a skew coordinate system is still Euclidean geometry)
Is this better:clj4 said:Look what you write:
"clj4 insists that the one-way speed of light is measurable in a coordinate-system independent away"
What credibility do you have with such an patently false and non-sensical opening statement?
Aether said:Is this better:
"clj4 insists that the one-way speed of light anisotropy is measurable in a coordinate-system independent way"
Aether said:I would like to understand this subtlety better.
Aether said:Ok, but this is equally true for GGT, aka Lorentz ether theory (LET), right? GGT/LET is a formulation of SR?
Right.
Well, remember that there's a philosophical difference. (I say philosophical because it doesn't manifest itself in any measurable way)LET "SR with a coordinate system that is incompatible with Newtonian physics", and LET "SR with a coordinate system that is incompatible with Newtonian physics".
