What exactly causes the Meissner effect
In summary, the Meissner effect in superconductors is caused by the Anderson-Higgs mechanism of QED in the medium, where surface currents or photons with an effective mass cancel out the applied magnetic field, leading to a short range force within the superconductor. This effect is also linked to the London effect and provides a consistent gauge theory for massive gauge bosons.
TheCelt
24
TL;DR Summary
What causes the effect when the critical temperature is reached?
I've read about the Meissner effect, it seems to suggest that a magnetic field passing through an object gets ejected/repelled (is that the right phrase to use?) from the object after said object has surpassed the critical temperature (i presume pressure as well?)... but what's actually happening at the atomic level to give rise to this effect?
TheCelt said:
Summary: What causes the effect when the critical temperature is reached?
Do you mean, passing through a superconducting object? There are multiple explanations, all correct.
  1. surface currents, created by back EMF, create magnetic fields that exactly cancel the applied field. Just as happens in conductors, but more effectively.
  2. Photons (which convey the E and B fields) acquire an effective mass inside the superconductor, which turns the EM interaction into a short range force. Hence only surface E & B fields.
https://en.m.wikipedia.org/wiki/Effective_mass_(solid-state_physics)https://en.m.wikipedia.org/wiki/Meissner_effect
Likes vanhees71
To be more precise: Superconductivity is effectively described by the Higgs mechanism of QED in the medium. In this connection one should really talk about the "Anderson-Higgs mechanism", because Anderson had the idea for superconductivity at the same time or even before Higgs, Brout, Englert, Kibble, Guralnik, and Hagen found it as the solution for the quibble about massive weak gauge bosons, i.e., how to get a consistent gauge theory with massive gauge bosons.
https://doi.org/10.1143/PTPS.86.43
Likes Michael Price
Which is also described at the end of the wikipedia article, where the link between the London effect and the Higgs mechanism is made.
Likes vanhees71
FAQ: What exactly causes the Meissner effect
1. What is the Meissner effect?
The Meissner effect is a phenomenon in which a superconductor expels all magnetic fields from its interior when cooled below a certain temperature, known as the critical temperature. This results in the superconductor levitating above a magnet and exhibiting perfect diamagnetism.
2. What exactly causes the Meissner effect?
The Meissner effect is caused by the expulsion of magnetic flux lines from the interior of a superconductor. This occurs due to the formation of superconducting Cooper pairs, which create a perfect diamagnetic response to any external magnetic field.
3. What materials exhibit the Meissner effect?
Only certain materials, known as superconductors, exhibit the Meissner effect. These materials have a critical temperature below which they can conduct electricity with zero resistance and exhibit perfect diamagnetism.
4. How does the Meissner effect impact technology?
The Meissner effect has numerous technological applications, including in magnetic levitation trains, MRI machines, and particle accelerators. It also allows for the creation of powerful electromagnets with zero energy loss.
5. What are some current research efforts focused on the Meissner effect?
Scientists are currently researching ways to increase the critical temperature of superconductors, as well as exploring new materials that exhibit the Meissner effect. They are also studying the fundamental physics behind the phenomenon to better understand its properties and potential applications.
