What Exactly is a Low drift sample and hold?
  • Thread starter Ian_Brooks
  • Tags
    Drift
In summary, a sample and hold is a circuit used in digital control to temporarily hold the analog value while the converter or following system performs an operation. Low drift means that the output does not change significantly during the hold time, and this is achieved by using a capacitor with low leakage and dielectric absorption, as well as a high-impedance input to the buffer amplifier. It is uncommon to find a high drift sample and hold as it is not desirable for its function.
Ian_Brooks
129
I realize a sample and hold is used in digital control whereby the circuit holds the analogue value steady for a short time while the converter or other following system performs some operation over that held time.
However what does it mean by having low drift?
You won't find anyone specifying a high drift sample and hold. It means the output doesn't change as much during the hold time as previously manufactured units in the same class.
For low drift, you need a capacitor with low leakage (easy), low dielectric absorption (need the right material), and you need a high-impedance input to the buffer amp in the S/H.
thanks
Related to What Exactly is a Low drift sample and hold?
1. What is the purpose of a low drift sample and hold?
A low drift sample and hold is used to accurately measure and hold a voltage signal for a certain period of time. It is often used in electronic circuits and data acquisition systems to maintain the stability of the measured signal.
2. How does a low drift sample and hold work?
A low drift sample and hold uses a capacitor to store and hold the input voltage signal. When a control signal is received, the capacitor is disconnected from the input and connected to the output, holding the voltage at a constant level until the next control signal is received.
3. What is the difference between a low drift sample and hold and a regular sample and hold?
The main difference between a low drift sample and hold and a regular one is the level of accuracy and stability. A low drift sample and hold has a lower drift rate, meaning it can maintain the held voltage more accurately over time compared to a regular sample and hold.
4. What factors can cause drift in a sample and hold circuit?
There are several factors that can cause drift in a sample and hold circuit, such as changes in temperature, power supply variations, and component aging. These can affect the accuracy and stability of the held voltage signal over time.
5. How can I choose the right low drift sample and hold for my application?
When selecting a low drift sample and hold, it is important to consider the required accuracy and stability of the held voltage, as well as the operating conditions and specifications of the circuit. It is also important to choose a reputable manufacturer and carefully read the datasheet for the chosen sample and hold device.
