What exactly is a position vector?
In summary: Q to R has initial point at Q and final point at R. The position vector of a point P is the "relevant" vector only if we are interested in the vector from (0,0) to P. If we are interested in the vector from Q to R, then the "position vector" is the vector from (0,0) to Q.In summary, a position vector is a vector that has its initial point at the origin (0,0) and final point at a given point. However, when using the term "vector" in a broader sense, a position vector is just one specific pair of points in an equivalence class of vectors. It is only considered the "relevant" vector if we
korters
Does a position vector ALWAYS have it's initial point at the origin (0,0)? What if there was an equivalent vector from P1 (NOT the origin) to P2 that has the same magnitude and direction as a vector with its initial point at the origin? Obviously these vectors would be equal, but would that mean the 1st vector that DIDN'T have its initial point at (0,0) is a position vector as well?
Thanks
Mathematics news on Phys.org
You are actually using the word "vector" in two different ways. Strictly speaking a vector is an equivalence class of pairs of points. A pair (P1,Q1) is equivalent to a pair (P2, Q2) if and only if P1x- Q1x= P2x[/sup]- Q2x and P1y- Q1y= P2y- Q2y. That is the sense in which the "vector" from (0,0) to (1, 1),say, is "equal to" the "vector" from (1, 2) to (2, 3). But when we talk about the "position vector" of a point we are talking about a single pair of points in that equivalence class: The pair of points (P,Q) with P= (0,0). So a "position vector" isn't a "vector" in the more general sense: once you stop working in Euclidean, "flat", space, the whole concept of "position vector" disappears.
The position vector of a point, P, is the vector having its initial point at (0,0) and final point at P. A vector having the same direction and length as OP but going
FAQ: What exactly is a position vector?
What is a position vector?
A position vector is a mathematical concept used to describe the location of a point in space relative to a reference point. It is typically represented by an arrow starting at the reference point and ending at the desired point.
How is a position vector different from a regular vector?
A position vector is a specific type of vector that describes the position of a point in space, while a regular vector can represent a variety of physical quantities such as force or velocity. In other words, a position vector has a specific purpose and meaning, while a regular vector can have multiple interpretations.
What are the components of a position vector?
A position vector has three components: x, y, and z, which represent the coordinates of the point in space relative to the reference point. These components can be represented as a column vector or as coordinates in a three-dimensional Cartesian coordinate system.
How is a position vector used in physics?
In physics, position vectors are used to describe the location of an object in space at a specific time. They are also used in vector calculus to calculate quantities such as displacement, velocity, and acceleration.
Can a position vector be negative?
Yes, a position vector can have negative components if the point is located in the negative direction of the coordinate system. However, the magnitude of a position vector is always positive, as it represents the distance between the reference point and the desired point.
