What exactly is negative adsorption?
In summary, negative adsorption is when the concentration of the adsorbate on the surface is less than its concentration in the bulk of the adsorbent.
Kaushik
282
TL;DR Summary
My book just gave a brief description about negative adsorption. Now that I have read it and didn’t understand it properly, I can’t forget it and want to know what it is.
My book states the following: When the concentration of the adsorbate is less on the surface relative to its concentration in the bulk, it is called negative adsorption.
I googled it and there are barely any source that talk about negative adsorption. I saw one or two videos and I believe that they are spreading the ‘wrong’ knowledge.
According to that video, when the concentration of the adsorbate on the surface is less than its concentration in the bulk of the adsorbent it is called negative adsorbtion. But according to me that definition is very vague. It gives us an idea that not only does the adsorbate penetrate through the surface but some of it is alos retained on the surface of the adsorbent. Then the concentration of the adsorbate inside and outside the adsorbent is compared to determine if the the adsorption is negative or positive.
I read one example online. When a dilute solution of potassium chloride is shaken wih blood charcoal concentration of the KCl in the solution (bulk) reduces.
Is it because the solvent (dipolar water molecule) is adsorbed on the charcoal and hence the amount of solvent in the bulk of the solution reduces due to which concentration of KCl increases. Is it?
Could you please help me in understanding negative adsorption?
(The video is in my native language and hence I haven’t shared it here.)
Chemistry news on Phys.org
Never seen the term. First thing that is difficult to stomach for me is the comparison of bulk concentration with surface concentration, apples and oranges.
Could be there is a way of defining both things in a way that will allow comparison, but I don't know it.
I suppose one could compare the relative % cross section of the adsorbate for a slice "at the surface" to a similar (parallel) slice "in the bulk". Not a term of art with which I am familiar, either.
Is this perhaps a translation issue? If your textbook is in English or you can direct us to some reference we can read it sure would help. There are advisors here here like @TeethWhitener and @chemisttree who may be acquainted with the term. I do not know about it.
Likes Kaushik
I’ve never encountered the term but the concept seems straightforward enough. If you add a sorbent and the concentration of your solute in the solution goes down, it’s positive adsorption; if you add a sorbent and the concentration of the solute goes up, it’s negative adsorption.
The reason is presumably that positive adsorption occurs when the solute has a higher affinity for the sorbent than the solvent (thus causing preferential adsorption of the solute onto the sorbent surface and lowering the concentration of the solute in the solution phase) and negative adsorption occurs when the solvent has a higher affinity for the sorbent than the solute.
Likes Kaushik and chemisttree
Thanks!
I found this on the internet and it is almost the same as your explanation. Now what I don’t understand is what do they mean by bulk (in the definition of positive adsorption). Is it the adsorbent’s bulk or the solution’s bulk?
That was my first intuition, but it doesn't make sense. The only way to make the concentration to go up is to add the solute itself, just adding a sorbent can't do that.
Unless the the sorbent adsorbs the solvent. Does "concentration of the adsorbate is less on the surface relative to its concentration in the bulk" mean that the solute/solvent ratio is less on the surface compared to the solution?
Likes Borek, 256bits and TeethWhitener
Kaushik said:
Summary:: My book just gave a brief description about negative adsorption. Now that I have read it and didn’t understand it properly, I can’t forget it and want to know what it is.
There are hordes of sites about adsorption mentioned positive and negative.
What do you think adsorption is if not a surface effect?
Adsorption is a surface process that leads to transfer of a molecule from a fluid bulk to solid surface. This can occur because of physical forces or by chemical bonds. Usually it is reversible (the reverse process is called desorption); then it is responsible not only for a subtraction of substances but also for release.
https://www.sciencedirect.com/topics/earth-and-planetary-sciences/adsorption
Either the concentration of the adsorbate on the surface, or rather within the small interstitial layer adjacent to the surface, is greater or less than its concentration in the bulk ( ie farther away from the surface ). That's all it is.
Likes chemisttree and Kaushik
That doesn't explain much.
Versus what happens with a concentrated solution of KCl, should have been added to the quote Page 180
https://books.google.ca/books?id=QoErDAAAQBAJ&pg=PA180&lpg=PA180&dq=dilute+solution+of+potassium+chloride+is+shaken+with+blood+charcoal+experiment.&source=bl&ots=I_EqM1ZBcf&sig=ACfU3U34gzqAX69vRZA1CY52OajB4aw2qw&hl=en&sa=X&ved=2ahUKEwj-xubDq8LqAhX7oHIEHRVaBE0Q6AEwA3oECAkQAQ#v=onepage&q=dilute solution of potassium chloride is shaken with blood charcoal experiment.&f=false
Likes Kaushik
@DrStupid in post 8 has the general idea I was getting at here. If the sorbent adsorbs solvent very strongly, then the relative concentration of the solute in the solution phase will go up.
Likes Kaushik, Borek and 256bits
Kaushik said:
Thanks!
“Bulk” on that website refers to what I’ve been calling the solution phase.
Likes Kaushik
All kinds of things potentially going in here for the blood/KCl/charcoal example. Blood is not simply a solute in a solvent. It is a mixture of solutes in a solvent. The fact that high concentrations of KCl causes a different type of adsorption can simply be due to a competitive binding between two or more solutes with the bound species modifying the surface chemistry of the sorbent. An increased salt content can cause a species in solution to adopt a different tertiary structure which would cause a change in how it presented its hydrophobic parts to the sorbent’s surface. Whatever the mechanism, the end result is neatly described with the terms “positive adsorption” and “negative adsorption.”
You might describe solute/stationary phase interactions in affinity chromatography to be an extreme example of positive adsorption and hydrophilic solute/reverse phase chromatographic interactions to be an example of negative adsorption.
  • Wow
Likes Kaushik, 256bits and TeethWhitener
Good point, missed that.
But sir they are not talking about the conc of solution they are talking about the concentration adsorbate
Which is an another bulk
Related to What exactly is negative adsorption?
1. What is negative adsorption?
Negative adsorption is a process in which molecules or particles are removed from a surface or solution, rather than being attracted to it. It is the opposite of adsorption, which is the attraction of molecules to a surface.
2. How does negative adsorption occur?
Negative adsorption can occur through various mechanisms, such as electrostatic repulsion, steric hindrance, or chemical interactions. In some cases, it can also be induced by changes in temperature or pressure.
3. What are some examples of negative adsorption?
One common example of negative adsorption is the process of ion exchange, in which ions are removed from a solution by binding to a surface with an opposite charge. Another example is the use of activated carbon to remove impurities from water through adsorption and subsequent negative adsorption.
4. What are the applications of negative adsorption?
Negative adsorption has various applications in industries such as water treatment, pharmaceuticals, and food processing. It is also used in analytical techniques, such as chromatography, to separate and purify different compounds.
5. How is negative adsorption different from absorption?
Negative adsorption and absorption are two distinct processes. Absorption involves the uptake of molecules or particles into the bulk of a material, while negative adsorption involves their removal from a surface or solution. Additionally, absorption is a thermodynamically favorable process, while negative adsorption is not always energetically favorable.
  • Earth Sciences
  • Other Physics Topics
9K
  • General Math
  • Thermodynamics
