What exactly is the detector of an ellipsometer measuring?
In summary, the PSA ellipsometer works by passing light through a polariser, hitting a sample and then passing through an analyser before being collected by a detector. The detector measures the optical power, which is modulated by the polariser and analyser orientations. This is done through multiple measurements of the intensity as a function of angle. The angle measured is between the polariser and analyser, but some systems also take into account the incidence angle on the sample.
Gabriel Maia
72
Hi. I'm curious about how a PSA (polariser-sample-analyser) ellipsometer works, especifically the detector bit. In an ellipsomenter, light passes through a polariser which puts it into a known polarisation state. After that it hits a sample (which may be an interface, a surface or a thin film) and because the Fresenel coefficients behave differently for different polarisation states, the components of the light interacting with the sample are modified differently, making the reflected light elliptically polarised. Light is then passed through an analyser and is collected by the detector.
After the analyser, the electric field has an amplitude given by the sum of the components of the electric field before the analyser and is oscillating in the direction prescribdeb by the analyser.
Now, my doubt is... what is the detector really measuring? Is it measuring the light intensity? How a single measurement can give any information about the sample?
Thank you very much.
Simply optical power. There are various choices as to how to measure optical power, but for a single beam system this can just be a photodiode. For imaging systems it can be a camera. All of the information is in the modulation of the intensity as a function of polarizer - analyzer orientation.
Sorry for the double post. I didn't see the "single measurement" question. It isn't a single measurement. The polarizer or analyzer spins and the intensity is measured as a function of angle. In some systems a waveplate is spun. In some systems the variable waveplate is electro optical for fast measurement. In some systems a single orientation of analyzer and compensator are found that null the signal. While this is only one position it still takes multiple measurements to find it.
Thank you very much. The angle the intensity is a function of is the angle between polariser and analyser, right? Don't they do measurements based on the incidence angle on the sample as well?
Related to What exactly is the detector of an ellipsometer measuring?
1. What is an ellipsometer?
An ellipsometer is a scientific instrument used to measure the optical properties of a material, such as its refractive index and thickness. It works by measuring the changes in polarization of light as it reflects off the surface of a sample.
2. How does an ellipsometer work?
An ellipsometer works by shining a beam of polarized light onto the sample and measuring the changes in the light's polarization as it reflects off the surface. These changes are then used to calculate the optical properties of the sample.
3. What exactly is the detector of an ellipsometer measuring?
The detector of an ellipsometer is measuring the intensity and phase of the reflected light. This data is used to determine the polarization state of the light and ultimately the optical properties of the sample.
4. What can an ellipsometer be used for?
An ellipsometer is commonly used in materials science and engineering to characterize thin films, such as those used in microelectronics and optics. It can also be used to study the surface properties of materials and their interaction with light.
5. How accurate are the measurements from an ellipsometer?
The accuracy of an ellipsometer depends on various factors such as the quality of the instrument, the type of sample being measured, and the expertise of the operator. However, modern ellipsometers can provide highly accurate measurements with a precision of up to 0.01 degrees for the measurement of polarization changes.
  • Materials and Chemical Engineering
  • Quantum Physics
  • Quantum Interpretations and Foundations
