What force is Block A exerting on Block B?
In summary, the conversation discusses a homework question regarding the force exerted on Block B by Block A. The necessary parameters for solving the problem are given by the teacher a week before the assignment is due. The equations relevant to the problem are the coefficient of friction and the formula for net force. The conversation then presents different attempts at solving the problem, including drawing a free body diagram and using Newton's laws. It concludes with a summarized solution using equations and assumptions about the acceleration of both blocks.
rarouch
This is a question that the teacher gives every week that we do in class. He gives the parameters without the actual numbers a week before so we can prepare.
The teacher will give:
- the masses for both blocks (different)
- the coefficient of friction for both blocks (different)
- the applied force on Block A
Question (what we have to figure out): What force is Block A exerting on Block B?
http://img580.imageshack.us/img580/7968/85935850.png"
Symbols weren't working for me but I'm assuming these equations are relevant:
coefficient of friction = Net Force / Normal Force
and
Fnet = mass * acceleration
I'm not sure how to go about at this. I would have to specify some numbers before I try. I would have to find all the forces acting on both objects first (one force would be the mass, one force would be the friction, and one would be the applied force for Block B). After that, I have no idea what to do.
and
When you look at both objects sliding together as a system, you have, in the x direction, the applied forces and the friction forces. Mass is not a force. Knowing these forces and the mass, you can calculate the acceleration of the blocks as they move together with the same acceleration.
To calculate the force between the blocks, you have to draw a free body diagram of one of the blocks and identify all forces acting on it, then apply Newton's law again to that block to solve for the unknown force. You should look at the other block also in the same manner, as a check on your work.
Alright, so I tried specifying numbers on my own. Here's my go at it:
Block A mass = 8 kg
Block B mass = 20 kg
Coefficient of kinetic friction for Block A = 0.20
Coefficient of kinetic friction for Block B = 0.40
Applied Force = 200 N
Find Normal Force
Block A
F = ma
F = 8kg x 9.8
F = 78.4 N
F = (78.4N)(0.20) - taking coefficient of friction into consideration
F = 15.68 N
Block B
F = ma
F = 20kg x 9.8
F = 196 N
F = (196N)(0.40)
F = 78.4 N
Find Acceleration
Total normal force = 78.4 N + 15.68 N = 94.1 N
Convert to kg = 94.1 N/9.8 = 9.60 kg
Acceleration
a = F/m
a = 200N/9.6kg
a = 20.83m/s^2 [right, assuming applied force is to the right]
Force of Block A on Block B
F = ma
F = (8kg)(20.83m/s^2)
F = 166.64 N [E]
I know I completely messed up one way or another. Would this be the right way, if not, can someone please correct me?
I probably didn't do this right.
try to draw a free body diagram of both the masses seperately. assume the accln. to be the same for both the masses, because otherwise they would break contact (i.e. if B has more acln. than that of A, also think why it is not possible that B has less accln. than that of A) and hence there will be no force btwn. them.
the forces on A:
A1. applied force F
A2. Friction opposing the motion.
A3. force exerted by B on A, also opposing motion.
add the forces vectorially and equate the result with mass X accln. of A.
the forces on B:
B1. Friction opposing the motion.
B2. force exerted by A on B, this time favouring the motion.
add the forces vectorially and equate the result with mass X accln. of B.
now from Newton's 3rd law put A3 = B2
now u have 3 eqn.s with three unknowns, assuming the accln. of the masses to be same. so u can solve it.
FAQ: What force is Block A exerting on Block B?
What is meant by "force" in this context?
In this context, force refers to a push or pull that causes an object to accelerate or change its motion.
How is force measured?
Force is typically measured in units of Newtons (N), which is equivalent to 1 kilogram-meter per second squared (kg·m/s²).
How do you calculate the force exerted by Block A on Block B?
The force exerted by Block A on Block B can be calculated using the formula F = m x a, where F is the force, m is the mass of Block B, and a is the acceleration of Block B caused by the force from Block A.
Are there different types of forces that Block A could exert on Block B?
Yes, there are different types of forces that Block A could exert on Block B, such as gravitational force, frictional force, or contact force.
Can the force exerted by Block A on Block B change over time?
Yes, the force exerted by Block A on Block B can change over time if the mass or acceleration of Block B changes, or if the distance between the two blocks changes.
