What Functions Satisfy These Specific Recursive Conditions?
  • MHB
  • Thread starter lfdahl
  • Tags
    Functions
In summary, determining functions is a crucial process in scientific research that allows scientists to understand and describe relationships between variables in a system. It involves using various methods and tools such as mathematical equations, graphs, and experimental data. While functions can be determined through theoretical analysis, experimentation is often necessary for validation. Linear functions have a direct proportional relationship represented by a straight line, while nonlinear functions have a more complex relationship. Functions are used extensively in scientific research to make predictions, test hypotheses, identify trends and patterns, and communicate findings.
lfdahl
MHB
749
Define the numbers $e_k$ by $e_0 = 0$, $e_k = \exp(e_{k-1})$ for $k \geq 1$. Determine the functions, $f_k$, for which
\[f_0(x) = x, \;\;\;\;f’_k = \frac{1}{f_{k-1}f_{k-2}\cdot\cdot\cdot f_0}\;\;\;\; for\;\;\; k \geq 1.\]
on the interval $[e_k, \infty)$, and all $f_k(e_k) = 0.$
Mathematics news on Phys.org
Hint:
Prove by induction, that $$f_k(x) = \ln^kx$$
- the $k$-fold composition of $\ln$ with itself.
Suggested solution:
We show by induction, that $f_k(x) = \ln^kx$, the k-fold composition of $\ln$ with itself. For $k = 0$, we have $f_0(x) = x = \ln^0 x$. Now assume, that $f_k(x) = \ln^kx$ for some $k \geq 0$. Then
\[f'_{k+1}(x) = \frac{1}{f_k(x)f_{k-1}(x)\cdot \cdot \cdot f_0(x)} = \frac{f'_k(x)}{f_k(x)}.\]
So
\[f_{k+1}(x) = \int \frac{f'_k(x)}{f_k(x)}dx = \ln f_k(x) + C = \ln \ln^kx+C = \ln^{k+1}x+C\]
for some constant, $C$. But
\[0 = f_{k+1}(e_{k+1}) = \ln^{k+1}e_{k+1}+C = C.\]
Hence $f_{k+1}(x) = \ln^{k+1}x$ establishing the induction.
FAQ: What Functions Satisfy These Specific Recursive Conditions?
What is the purpose of determining functions?
Determining functions allows scientists to understand and describe the relationship between different variables in a system. It helps us predict how changes in one variable will affect the others, and can be used to identify patterns and make accurate conclusions about the behavior of a system.
How do scientists determine functions?
Scientists use a variety of methods and tools to determine functions, including mathematical equations, graphs, and experimental data. They may also use computer software or conduct experiments in a controlled environment to gather data and analyze the relationships between variables.
Can functions be determined without experimentation?
Yes, functions can also be determined through theoretical or mathematical analysis. By using principles and laws of science, scientists can make predictions and determine functions without conducting experiments. However, experimentation is often necessary to validate these theoretical predictions.
What is the difference between a linear and nonlinear function?
A linear function is one in which the relationship between the variables is directly proportional and can be represented by a straight line on a graph. Nonlinear functions do not follow a straight line and have a more complex relationship between variables, such as exponential or quadratic functions.
How are functions used in scientific research?
Functions are essential in scientific research as they allow scientists to analyze and understand the behavior of complex systems. They are used to make predictions, test hypotheses, and identify trends and patterns in data. Functions also help scientists communicate their findings and make their research more accessible to others.
