B What gives satellites their tangential velocity?
Satellites achieve tangential velocity primarily through a two-phase launch process. Initially, they are launched vertically to penetrate the lower atmosphere, followed by a horizontal acceleration to reach the required speed for orbit. This horizontal motion is crucial for maintaining a stable orbit around the Earth. Understanding this process is essential for comprehending how satellites remain in space for extended periods. The mechanics of this launch strategy highlight the complexities of orbital dynamics.
phyiscsormath
What gives satellite a tangential velocity?
:welcome:
I guess the short answer is "that's rocket science"!
Basically the satellite is launched vertically to get through the lower part of the atmosphere, but then accelerates horizontally to achieve the necessary tangential velocity.
There's a good explanation here, for example:
https://www.scienceabc.com/nature/u...into-orbit-and-kept-up-there-for-so-long.html
Likes phyiscsormath and Ibix
PeroK said:
:welcome:
Thank you!
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
