What happened to my pic editor under W10?
  • Thread starter kyphysics
In summary, the user's cell phone photos won't open in the Windows 10 program to edit them anymore, but before the problem occurred, they were able to crop and rotate them the same way they have done in the past. The problem is that now when they try to do that, the entire box around the picture shrinks or enlarges accordingly. The user is trying different software to see if any of them work, but if not, they might want to try reinstalling the program that's causing the problem.
kyphysics
676
437
I have Windows 10.
When I take pictures with my cell phone and transfer them to my laptop (with Windows 10), I used to open them up (they're in JPG form) and be able to edit them. The edit button in the program that opens the JPG file allows you to do stuff like crop and rotate.
I've ALWAYS used crop and rotate to "blot out" background stuff that I didn't want. For example, if I had an apple in a picture that had all sorts of other fruits around it. I could select crop and rotate and a square would appear around my entire picture. If I clicked the horizontal lines (above and below the picture), I could drag those lines up or down more to edit out or edit in more or less stuff vertically in my picture.
Likewise, if I clicked the vertical lines on the left and right sides of the picture, then I could drag them to edit out more or less stuff in the picture from the sides.
Suddenly today for no reason that I'm able to determine, when I select crop and rotate, it won't allow me drag the vertical lines or the horizontal lines around my pictures only. Instead, when I drag any of the lines in the box around my pictures, the ENTIRE box will shrink or enlarge accordingly.
Before, if I drag the top horizontal line up or down, the vertical lines wouldn't be affected and vice versa. Now, suddenly, when you drag one type of line, the other types get affected to and instead of enlarging or shrinking one part of the picture the entire picture being affected.
Not sure if taht made sense, but does anyone know what to do to fix the problem and get back to the original way it worked? I didn't even do anything to the program that opens up pictures.
Computer science news on Phys.org
JPEG is a very well defined format for storing images, it's not likely that something has gone wrong with the original image capture.
What is more likely is that whatever software you have in the laptop to process the files has somehow got into a weird setting.
There are huge amounts of software available which process jpg files one way or another, a lot of them are free.
Try a few different ones, and if there seems to be no problem there, try reinstalling the program which is misbehaving.
Check also that your laptop keyboard doesn't have a stuck down key, that can lead to all kinds of weirdness.
Related to What happened to my pic editor under W10?
1. What happened to my pic editor under W10?
When you upgraded to Windows 10, your previous pic editor may have been replaced with the default Windows Photos app. This is a built-in photo editor that comes with Windows 10. However, your previous pic editor should still be available in the Windows Store.
2. How do I find my previous pic editor in the Windows Store?
To find your previous pic editor, open the Windows Store and search for the name of your editor. If it is not available, you may need to contact the developer for an updated version that is compatible with Windows 10.
3. Can I still use my previous pic editor with Windows 10?
If your previous pic editor is not available in the Windows Store or does not have an updated version, you may still be able to use it with Windows 10. Right-click on the photo you want to edit, select "Open with" and then choose your previous pic editor from the list.
4. Why did my pic editor disappear after upgrading to Windows 10?
It is possible that your previous pic editor is not compatible with Windows 10, or that it was not automatically transferred during the upgrade process. In this case, you may need to manually install the editor from the Windows Store or contact the developer for assistance.
5. Is the Windows Photos app a good replacement for my previous pic editor?
The Windows Photos app has many basic photo editing features, but it may not have all the advanced features that your previous pic editor had. It is a good option for basic editing, but you may prefer to continue using your previous pic editor for more advanced edits.
  • Computing and Technology
  • Astronomy and Astrophysics
