What happens if a low energy photon collides with an atom in the ground state?
In summary, when a small energy photon collides with an atom in ground state whose energy level gap is greater than the photon's energy, the most likely case is that it will pass through without interaction. However, scattering is also possible and the atom may gain a small amount of momentum. When a medium is shined with light, the atoms or molecules may absorb the light and emit it again or convert it to heat. This is why the medium becomes warmer when it is shined with light.
fxdung
388
23
What happen if a small energy photon collide an atom in ground state that the gap between energy levels of atom is greater than energy of photon?It seems that the medium absorbs light and transform to heat?
It might just pass through without interaction - the most likely case. Scattering is also possible: The photon changes its direction, the atom gains a tiny bit of momentum.
Visible light and most common gases are an example.
Why the medium become warmer when it is shined with light?What happen when it absorbs light?
Then some atoms, molecules, or solids there have transitions that can absorb the light. Sometimes they will emit light again, sometimes they lose their energy without emitting radiation (converting it to heat).
Usually most atomic transitions are in the visible range. So if you have a light with a slightly lower energy, then that means your light is in the infrared range.
Infrared light is typically not absorbed by atomic transitions, but rather it is absorbed in molecular rotational or vibrational modes, which are lower energy. If a medium has such modes then it will absorb infrared, otherwise it will be transparent to infrared.
Related to What happens if a low energy photon collides with an atom in the ground state?
1. What is a low energy photon?
A low energy photon is a particle of light with low energy, meaning it has a longer wavelength and lower frequency compared to higher energy photons. Low energy photons are typically in the visible or infrared range of the electromagnetic spectrum.
2. What is an atom in the ground state?
An atom in the ground state is the lowest energy state an atom can be in. This means that all of the atom's electrons are in their lowest possible energy levels or orbitals. In this state, the atom is considered to be in its most stable form.
3. What happens when a low energy photon collides with an atom in the ground state?
When a low energy photon collides with an atom in the ground state, the atom's electrons can absorb the energy from the photon and move to a higher energy level. This process is known as excitation. Alternatively, the photon can be scattered or reflected off the atom without any energy transfer.
4. How does the energy of the photon affect the outcome of the collision?
The energy of the photon determines whether it will be absorbed, scattered, or reflected by the atom. Low energy photons are more likely to be absorbed and cause excitation of the atom's electrons, while higher energy photons are more likely to be scattered or reflected.
5. Can a low energy photon cause an atom to emit a photon?
Yes, a low energy photon can cause an atom to emit a photon through a process called spontaneous emission. This occurs when an excited electron in the atom returns to its ground state, releasing the excess energy as a photon. The emitted photon will have the same energy as the absorbed photon, resulting in a lower energy state for the atom.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
