What happens if an acid is added to this buffer?
  • Thread starter FredericChopin
  • Tags
    Acid Buffer
In summary: So while the net pH change is positive (down), the total number of protons (H+) in the solution has actually decreased.
FredericChopin
101
In grapes, there is an equilibrium between tartaric acid and hydrogen tartrate and hydrogen ions:
(1) H2T (aq) <=> HT- (aq) + H+
NOTE: "T" stands for the tartrate ion C4H4O6.
There is also a buffer system in grapes, involving a solubility equilibrium of potassium hydrogen tartrate and hydrogen tartrate and potassium ions:
(2) K+ (aq) + HT- (aq) <=> KHT (s)
What happens if you add H2T to this system?
N/A
If I added an acid to this system, the buffer will oppose the decrease in pH and so the pH will stay the same, right?
Suppose I added H2T to this system: then I have increased the concentration of H2T, and due to Le Chatelier's Principle, equilibrium (1) will shift to produce more HT- and H+. This will increase the concentration of HT- however, so equilibrium (2) will shift so that K+ reacts with HT- to produce KHT, which will precipitate. But hold on, the concentration of H+ has increased, meaning the pH has gone down. The buffer has not opposed a decrease in pH!
What's going on?
Assuming you managed to prepare solution that behaves the way you describe, you add the acid AND remove the conjugate base at the same time, so it is not as simple as just adding acid to the buffer.
Besides, when you add acid (base) to the buffer pH always goes down (up) - just slower than if the buffer wasn't present.
The reason for this is because while the acid is neutralized, remember that base was used to neutralize it. You lose hydroxide ions from solution and the volume of acid added will decrease the concentration of all entities involved.
FAQ: What happens if an acid is added to this buffer?
Q1: What is a buffer solution?
A buffer solution is a mixture of a weak acid and its conjugate base (or a weak base and its conjugate acid) that helps to maintain a relatively constant pH when small amounts of acid or base are added.
Q2: What happens to a buffer solution when an acid is added?
When an acid is added to a buffer solution, the pH of the solution will decrease slightly. However, the buffer will resist large changes in pH due to the presence of the weak acid and its conjugate base.
Q3: Will the buffer solution neutralize the added acid?
No, a buffer solution will not neutralize the added acid. Instead, it will minimize the change in pH by absorbing some of the added acid into the weak acid component of the buffer.
Q4: What happens if too much acid is added to a buffer solution?
If too much acid is added to a buffer solution, the pH will eventually drop to a point where the buffer can no longer effectively resist changes. This is known as the buffer capacity and is dependent on the concentration of the buffer components.
Q5: Can a buffer solution also resist the addition of a base?
Yes, a buffer solution can also resist the addition of a base by absorbing it into the weak base component of the buffer. The buffer's ability to resist changes in pH works in both directions, whether an acid or base is added.
