What happens if there is no brain plasticity
In summary: Well how you go about... creating the carbon nanotube neurons?There's no one definitive way to do this. You could theoretically print the carbon nanotubes using a 3D printer. Alternatively, you could synthesize the carbon nanotubes using a chemical process.
fredreload
250
What would happen if there is no brain plasticity? Would the brain be incapable of gaining new memory? Say you grow to a certain age, obtain enough memory, feeling, and such then the brain plasticity stops(yes, I know it is not supposed to), what would happen to that person? Is he still able to perform like a normal individual?
Biology news on Phys.org
I think that requires a nuanced definition of plasticity. Does it include forming new memories? If so, then you'd essentially get the plot of '50 First Dates'.
Well, I think you answered your own question. The answer is NO, you can't form new memories without brain plasticity. The word "forming" implies change. You can't reform anything absent plasticity. It's the plasticity of the fiber connections between neurons in the cortex that form memories. We neuroscientists call these "Hebbian connections."
Likes jim mcnamara
There are people who - due to trauma or disease - have limited or no short term memory. In general, they cannot live alone or unassisted - safely. So, the neural plasticity you talked about is important to everyday living.
How about anyway to induce brain plasticity? Excite the external of the neuron to create new memory path using electromagnetic radiation or chemical to get the correct memory structure?
https://en.wikipedia.org/wiki/Hebbian_theory
Hmm, kind of a bummer they can't train artificial neurons to perform neural plasticity. You think they have a way to bypass that? I was originally thinking of a brain structure made of 3d printing with a different type of material to substitute for neurons, but it wouldn't work unless it can do neural plasticity.
A different type of material? Like what? Do you really think we can "bake" up a chemical compound that functions like a neuron and put it in a 3D printer? It's not that easy.
It's not difficult at all to do this. However, modeling a single neuron is not the level of modeling that you want to focus on. You want to focus on the mesoscopic level of the population that we model as coupled oscillators. You can model on the order of 10,000 neurons as a "node" and use one parameter as a "weight" to simulate the modifiable synapse. We can simulate these using non-linear coupled ODE's. Again, it's not that difficult to simulate these oscillators in electronic circuits.
http://sulcus.berkeley.edu/wjf/DF_Principe_IEEEAnalogVLSI.pdf
We've found that the limiting factor is in the complexity of the scaling factor of the oscillators. The actual biological brain is a 3D structure which allows for a rich and complex interconnectivity. Trying to emulate that 3D architecture with electronic circuitry is the current challenge we face.
A different type of material like carbon nanotube that can be 3d printed into a neuron shape, it doesn't have to be a real neuron, as long as it runs electrical synapses it should work as a real neuron, it doesn't need to be alive. Well how you go about creating neural plasticity for a carbon nanotube brain structure is where I got lose. My idea is substituting real neuron with carbon nanotube because if you 3d print a brain with real neurons, a lot of things can go wrong, but if you 3d print just the structure and substitute it with a more durable material then it should work better, again it is never tested. So if you would let me know how to create neural plasticity for carbon nanotube or any other material it would be cool. The problem is I think neural plasticity is built into the internal structure of the neuron so that feature can't really be transferred to a carbon nanotube.
That's not going to happen. A neuron is a very complex system with a lot of moving parts. A carbon nanotube comes just as advertised, it's just carbon. You're not going to get any functionality out of it other than structural.
How about:
http://www.research.ibm.com/articles/brain-chip.shtml
"We envision augmenting our neurosynaptic cores with http://www.modha.org/papers/013.CICC2.pdf to create a new generation of field-adaptable neurosynaptic computers capable of online learning."
Likes fredreload
Hmm, we'll need some type of material that can be updated with structural changes to simulate brain plasticity. Maybe some type of nano machines would do the work? This sounds like a hard problem.
Hardware sounds like a possible answer. Devices like hard drive can easily changes their memory.
atyy said:
How about:
Is it water proofed?
I think the consequences would be pretty severe. At least some types of plasticity (https://en.wikipedia.org/wiki/Homeostatic_plasticity) are required just to remain stability. Without this, the network would be likely to end up in either an epileptic or braindead state, or at the very least a state that is far from its operating point.
Not if we can create a virtual brain with neural plasticity and link that to the real brain
Was this a response to my post? I'm not entirely sure how what you are proposing would solve the issues of stability that arise when homeostatic plasticity is removed. It may be possible to artificially inject current into a neuron in order to keep the input statistics fixed over time, rather than adjusting the way the neuron responds to those inputs via homeostasis. That's not really the same as adding a virtual brain with plasticity though, it's just adding some kind of control system.
Well, we'll have to agree that a real brain can link to a 3d brain inside a computer, theoretically
I'm not clear on what that link would entail. Having a conversation involves linking two brains in some sense. My two brain hemispheres can be considered as two linked brains in some sense, as can any arbitrary partition of my brain into two subsystems. Whether a real brain can be linked to a brain inside a computer in some meaningful sense I'm not sure.
Ya, it's quite an interesting idea, my guess is it works, we just need a way to test it outP.S. And if I am wrong, nothing to lose, another reason I guess it would work is because the artificial brain would also contain a consciousness
Related to What happens if there is no brain plasticity
1. What is brain plasticity?
Brain plasticity, also known as neuroplasticity, refers to the brain's ability to change and adapt throughout an individual's lifetime. It allows the brain to reorganize and form new neural connections in response to experiences, learning, and injury.
2. Why is brain plasticity important?
Brain plasticity is important because it enables us to learn new skills, form memories, and recover from brain injuries. It also plays a critical role in our cognitive development and allows us to adapt to changes in our environment.
3. What happens if there is no brain plasticity?
If there is no brain plasticity, our brains would not be able to adapt to new experiences or form new connections. This would severely limit our ability to learn, recover from injuries, and adapt to changes in our environment. It could also lead to cognitive impairments and developmental disorders.
4. Can brain plasticity change over time?
Yes, brain plasticity can change over time. It is most prominent during childhood when the brain is still developing, but it continues throughout adulthood. However, as we age, brain plasticity may decrease, making it more difficult to learn new skills or recover from injuries.
5. How can we enhance brain plasticity?
There are several ways to enhance brain plasticity, including engaging in new and challenging activities, getting enough sleep, and maintaining a healthy diet. Regular exercise and practicing mindfulness and meditation techniques have also been shown to improve brain plasticity. Additionally, certain therapies, such as occupational therapy and speech therapy, can help individuals with brain injuries or developmental disorders improve their brain plasticity.
  • Biology and Medical
20K
