What happens to a light photon when it hits glass?
In summary, a photon is a particle that carries light energy. It has just one wavelength, and it is made up of all the frequencies in a light spectrum.
askbbj
Using quantum mechanics, what happens when a photon of light hits glass?
Momentum= Mass x velocity
I am not sure of my answer but suffice to say the following:
Assuming the collision between the photon particle and those in the glass is inelastic, then going by the conservation of momentum, we can say that the total momentum before the collision is the same as that after. If that is the case, then the total energy before is the same as that after since energy is propotionate to momentum. But I also understand that the speed of light slows down in glass. So if this is the case, it contradicts what I had said earlier about the energy of light being constant throughout. Anyone who begs to differ in opinion?
Come again? Energy is not proportional to momentum. Consider, for instance a reference frame in which total momentum is zero before and after the event.
Where in your reasoning have you done that? (Not saying you haven't, just asking.)
Collision?
What about the momentum of the glass.
Well, for a photon E=pc, no?
This thread looks relevant: https://physics.stackexchange.com/questions/44509/photon-energy-momentum-in-matter
Quantum mechanically speaking, what is the relationship between the photon's energy and its frequency? (Hint: historically, this is one of the very first relationships* that ushered in quantum mechanics.)
Does the photon's frequency change when it enters the glass?
*[The relationship I'm speaking of was originally discovered by Max Planck, but it was Albert Einstein that really nailed the significance of it in one of his 1905 papers (he published several papers in 1905; this was one of them).]
Sure. But the line of reasoning had to do with momentum conservation for the whole system, not just the photon. If we adopt a frame where system momentum is zero and if energy were proportional to momentum it would follow that system energy is zero. But energy is non-negative for each system component separately. To achieve a total energy of zero, the photon energy needs to be zero (no photon) and the glass energy needs to be zero (E=mc^2 -- no glass either).
I was just suggesting that’s where askbbj got that idea from.
Likes jbriggs444
Hi is a light photon consist of all the wavelengths in a spectrum?
No, it will have just the one wavelength.
Haruspex is correct. @askbbj, are you able to answer my question about the relationship between a photon's energy and its frequency?*
*(This is the hint question about Albert Einstein's 1905 paper. Another hint: it's the same paper for which he won the Nobel Prize.)
Please do not write that. It is convenient, but not correct. I know that this is usually written in a simplifying manner to help students learn, but most students have a hard time unlearning it afterwards. The typical Fourier modes in the decomposition of a light field into harmonic oscillators are monochromatic. This is why you do this decomposition. However, these modes are not the definition of what a photon is. Single photons do not need to be monochromatic. In fact, no real single photon source is even close to that. A single photon may be spectrally narrow or broad. This is not a defining element. You just need the photon number to be 1 in your basis of choice. It is also a very common practice to spectrally tailor single photons (see e.g. https://iopscience.iop.org/article/10.1088/0034-4885/75/12/126503/meta or https://journals.aps.org/prb/abstract/10.1103/PhysRevB.94.165310).
Getting back to the initial question: The transmission of light through a medium is nontrivial, but usually, this question does not aim at momentum conservation, but about how to interpret the fact that the photon may only be transmitted or reflected as a whole. There is no 96% transmitted and 4% reflected photon. What does this imply to you?
Related to What happens to a light photon when it hits glass?
1. What is a light photon and how does it interact with glass?
A light photon is a tiny particle of energy that makes up light. When it hits glass, it can either be reflected, absorbed, or transmitted through the material.
2. Why does light pass through glass instead of being absorbed?
Glass is a transparent material, meaning that its molecules are arranged in a way that allows light to pass through without being absorbed. This is due to the fact that the energy levels of the glass molecules do not match the energy of the light photons, so they are not absorbed and can pass through.
3. What happens to the light photon when it is reflected by glass?
When a light photon hits glass at an angle, it can be reflected off the surface. This is because the glass molecules cause the light to change direction, bouncing it back in the same angle it came in at. This is known as specular reflection.
4. Can the light photon change speed when it passes through glass?
Yes, light can change speed when it passes through different materials, including glass. This is due to the fact that glass has a higher refractive index than air, causing the light to slow down as it passes through.
5. What determines the amount of light transmitted through glass?
The amount of light transmitted through glass depends on its thickness and the angle at which the light hits the surface. Thicker glass will absorb more light, and light that hits the surface at a perpendicular angle will be transmitted more easily than light that hits at an angle.
  • Quantum Physics
  • Atomic and Condensed Matter
