What happens to entropy when doubling the volume?
In summary, the container of volume 2V is divided into two compartments of equal volume by an impenetrable wall. One of the compartments is filled with an ideal gas with N particles. The gas is in equilibrium and has a temperature T. When the separating wall is suddenly removed, the total energy, the entropy, the temperature, and the pressure change.
fuselage
A container of volume 2V is divided into two compartments of equal volume by an impenetrable wall. One of the compartments is filled with an ideal gas with N particles. The gas is in equilibrium and has a temperature T. How does the total energy, the entropy, the temperature, and the pressure change when the separating wall is suddenly removed? (There is no interaction with the surroundings).
I'm guessing there are several, but perhaps dE=TdS-PdV+μdN, dS/dV=P/T, and PV=NkT are the most important ones.
Here's what I think is the answer, but I want to be sure:
Since there is no energy added to the system, and there is no reason energy would be removed from the system, the total energy should remain the same.
Since no thermal energy has been added or removed, the temperature should also remain unchanged.
Since the temperature is unchanged, no particles have been added or removed, and the volume has been doubled, we can use PV=NkT to deduce that the pressure has to be halved.
The problem is that I haven't found a good way of showing how the entropy would increase. It's obvious that it should increase, but I don't know by how much. Help?
Your answers for the energy, temperature, and pressure are correct.
As a hint for getting the change in entropy, can you think of a reversible way to get from the initial to the final state?
Likes Chestermiller
Moving the wall to one side of the container through a quasistatic process (i.e. "infinitely slowly"). But this still doesn't help me find how much the entropy increases.
EDIT: Wait, since entropy does not increase in a reversible process, is the entropy the same? But hasn't the number of microstates increased?
The entropy of a system may or may not change during a particular reversible process. It depends on the process.
You said that you would move the wall quasi-statically. That's good. But that doesn't fully describe the process that you have in mind. You want to end up in a particular final state. You can allow the system to interact with the environment during the reversible process in such a way that you get to the desired final state. And you can give the environment whatever property you wish.
But there is no interaction with the surroundings as stated in the original problem. I don't think comparing this to a reversible process is of much help. What I need help with is finding a relation I can use to explain how much the entropy increases.
I've tried using dS/dN=-μ/T , dS/dV=P/T , and dE=TdS-PdV+μdN, but they don't really tell me anything (or I'm missing something).
Entropy is a state variable. No matter what particular process you use to get the system to go from the given initial state to the given final state, the change in a state variable of the system is independent of the particular process. This is true whether the process is reversible or irreversible and whether the system interacts with the environment or not.
I think I figured it out. Since the process is isothermal, we know that ΔQ=ΔW. We also know that W=NkT⋅ln(V2/V1).
Since ΔS=ΔQ/T, it follows that ΔS=Nk⋅ln(V2/V1)), which in out case yields ΔS=Nk⋅ln2
Right?
Which process are you thinking about here?
The process of the original problem.
What is the value of ΔQ for the original process where there is no interaction with the surroundings?
What is the value of ΔW for the original process?
Even though the final state has the same temperature as the initial state, the original process is not isothermal. The process is irreversible. During the process, the system is not in thermal equililbrium. So, the temperature is not defined during the process.
To add to what TSny said, once you have established the initial and final equilibrium states of the system as a result of the actual irreversible process path, the next step is to completely forget about the actual process path. To get the entropy change, you need to devise (dream up) a reversible path that takes you between the same initial and final equilibrium states, and calculate the integral of dq/T for that path. Any reversible path will do (there are an infinite number of reversible paths, and they all give the same value for the integral). Just choose one that is easy to calculate the integral for.
Chet
Likes TSny
FAQ: What happens to entropy when doubling the volume?
1. What is entropy?
Entropy is a measure of the disorder or randomness in a system. It is a thermodynamic property that describes the distribution of energy and matter within a system.
2. How is entropy related to volume?
Entropy is directly proportional to the volume of a system. This means that as the volume of a system increases, the entropy also increases.
3. What happens to entropy when doubling the volume of a gas?
When doubling the volume of a gas, the entropy also doubles. This is because the particles in the gas now have more space to move around and there are more possible arrangements, leading to an increase in disorder.
4. Does doubling the volume always increase entropy?
No, doubling the volume does not always increase entropy. It depends on the type of system and the conditions under which the volume is being changed. In some cases, increasing the volume may actually decrease entropy.
5. How does entropy change in an isolated system when doubling the volume?
In an isolated system, the total entropy remains constant. This means that if the volume is doubled, the entropy of one part of the system may increase, but the entropy of another part will decrease by an equal amount, resulting in no change in total entropy.
