What happens to infinitesimal time in path integral
In summary: Ballentine's path integral book is very helpful. In summary, it is a tool used to study systems in equilibrium. The limit as N tends to infinity is where the mathematical difficulties arise. However, most of the time the convergence of the path integral can be proved.
Ravi Mohan
196
Hi,
I am studying path integral formulation from Ballentine. Till equation 4.50, I follow quiet well.
[tex]
G(x,t;x_0,t_0) = \lim_{N \to \infty}\int\ldots\int\left(\frac{m}{2\pi i\hbar\Delta t}\right)^{\frac{N+1}{2}}\exp{\sum_{j=0}^{N}\left(\frac{im(x_{j+1}-x_j)^2}{2\hbar\Delta t}-V(x_j)\right)}dx_1\ldots dx_N
[/tex]
I also follow that in continuum limit, summation converts to integral (argument of exponent). I am wondering what happens to the [itex]\Delta t[/itex] in the expression [itex]\left(\frac{m}{2\pi i\hbar\Delta t}\right)^{\frac{N+1}{2}}[/itex].
It goes into the definition of functional integral
I am sorry, I was not clear enough. In the continuum limit, [itex]N[/itex] tends to infinity and [itex]\Delta t[/itex] tends to zero. From the given expression, the limit amounts to infinity (there is no indeterminate form) so how come we get a finite number?
The situation is a little bit more complicated. When you define the functional integral taking the [itex]N\to \infty[/itex] limit (i.e. [itex]\Delta t\to 0[/itex]), you also define a "functional measure":
\left(\sqrt{\frac{m}{2\pi i\hbar \Delta t}}\right)^N\int \prod_{i=0}^N dx_i \to \int \mathcal{D}x.
The hope is that taking the product of an infinite number of integral divided by an infinitesimal quantity the final result is finite. Anyway, most of the times the actual convergenge of the path integral cannot be proved.
And if you actually carry out the ##N## integrations before taking the limit (which you can do explicitly in special cases such as a free particle or a harmonic oscillator), you find that the final result is finite and well-defined in the limit.
There are deep mathematical issues involved here.
Rigorously one must go to some some advanced math such as Hida distributions to take care of them:
http://arxiv.org/abs/0805.3253
This isn't the only area that has this problem (ie rigorously defining such integrals). Path integrals are the same as the Wiener integral but in imaginary time. Because of that there is a close connection between stochastic white noise theory and path integrals at the mathematical level:
http://mathlab.math.scu.edu.tw/mp/pdf/S20N41.pdf
Interestingly both the modern mathematical formalism of QM and Hida distributions make extensive use of Rigged Hilbert Spaces. That may be trying to tell us something important - but exactly what -:confused: :confused::confused::confused:
Thanks
Bill
Likes 1 person
FAQ: What happens to infinitesimal time in path integral
What is an infinitesimal time in path integral?
An infinitesimal time in path integral is a concept in quantum mechanics that describes the evolution of a system over an extremely short period of time. It is often used in the path integral formulation of quantum mechanics, where the path to be integrated is divided into small segments and the contribution of each segment is summed up.
How does path integral handle infinitesimal time?
In the path integral formulation, infinitesimal time is handled by dividing the path into small segments and calculating the contribution of each segment. This allows for the calculation of the total path integral over a continuous range of time.
Does infinitesimal time have a physical meaning?
No, infinitesimal time does not have a physical meaning. It is a mathematical concept used in the path integral formulation to simplify calculations and allow for the integration over a continuous range of time.
Can infinitesimal time be measured?
No, infinitesimal time cannot be measured because it is a theoretical concept that describes an extremely short period of time. It is not possible to accurately measure time at such a small scale.
How does the concept of infinitesimal time relate to quantum mechanics?
The concept of infinitesimal time is closely related to quantum mechanics, as it is used in the path integral formulation to calculate the probability of a quantum system evolving from one state to another. It allows for the integration over all possible paths, which is a key aspect of quantum mechanics.
