What happens to non-respiratory gases in the lungs?
  • Thread starter Thread starter Amaterasu21
    Diffusion Gases
The discussion centers on the diffusion of gases in the lungs, specifically questioning why gases like nitrogen and argon, despite being small non-polar molecules, do not diffuse across alveolar and capillary membranes like oxygen and carbon dioxide. It suggests that the lack of a diffusion gradient, due to the partial pressures of these gases in the blood being similar to those in the air, could explain their minimal diffusion. The conversation also highlights concerns regarding increasing atmospheric carbon dioxide levels, which may reduce the efficiency of CO2 diffusion from blood to air, potentially impacting waste removal and blood pH regulation. The mention of the Lake Nyos disaster serves as an extreme example of rapid CO2 changes affecting human safety. Additionally, the adaptation of humans to lower oxygen levels at high altitudes is noted, along with references to decompression sickness related to nitrogen. The discussion concludes with a call for more research on the solubility of inert gases in blood, emphasizing the need for updated data on gas behavior in biological systems.
Amaterasu21
TL;DR Summary
What happens to nitrogen, argon etc. in the alveoli?
Hi, a thought just occurred to me.
We all learned in school that oxygen diffuses from the air in the alveoli into the blood, and carbon dioxide diffuses from the blood into the air to be breathed out. But they never mention nitrogen, argon or any of the other gases in the air! Does something prevent them from diffusing across? Given that these are all relatively small non-polar molecules I'd imagine they'd all diffuse easily through the alveolar and capillary membranes, so probably not that. Or is the partial pressure of these gases dissolved in the blood identical to that in the air, leading to no diffusion gradient? In which case, blood contains way more dissolved nitrogen than I thought!
A second thought too: since the concentration of carbon dioxide in our atmosphere is going up, that must be reducing the concentration gradient for CO2 between the air and our deoxygenated blood. Does that mean carbon dioxide diffusion is becoming less efficient and thus our burning of fossil fuels is inhibiting our ability to remove wastes and control blood pH? I suppose it must be, but is this a negligible effect or a real concern?
Biology news on Phys.org
Here is an extreme example: an underwater landslide vigorously disturbed Lake Nyos in the Cameroons. Vast volumes of released CO2 killed more than 1000 people. Humans cannot adapt that fast.
https://en.wikipedia.org/wiki/Lake_Nyos_disaster
Going up in elevation:
Humans respond to lower partial pressures of O2 by slowly increasing hematocrit (hemoglobin levels in blood) to compensate. So we can adapt to very slow changes. Andean people have genetic changes to accommodate lower partial pressures of O2 at elevation > 2700m
You may want to check out Decompression sickness ( bends) - another partial pressure change of gases: nitrogen in this case
https://www.ncbi.nlm.nih.gov/books/NBK537264/
So, what you thought is pretty reasonable, except maybe for the rapidity of change.
Likes berkeman and pinball1970
Amaterasu21 said:
Summary: What happens to nitrogen, argon etc. in the alveoli?
There is the solubility of the gas in blood to take into account.
You can look at these 2 sites to try and make some heads and tails of it.
wiki has a list of ingredients in the blood - no mention of Argon, perhaps it it too faint to list??
https://en.wikipedia.org/wiki/List_of_human_blood_components
This lists the solubility of inert gases in blood, although its from 1981 ( 40 years ago ) and somewhat incomplete, ...
https://www.researchgate.net/publication/16933250_Solubility_of_inert_gases_in_biological_fluids_and_tissues_A_review
At the end conclusion they write,
This compilation has attempted to summarize the equilibrium property of gas molecules most important to hyperbaric research and operations. How much gas can actually dissolve in the body'? Except fbr the well-studied clinical anesthetics cyclopropane, nitrous oxide. and halothane. and the common radiotracers krypton and xenon. the question remains unanswered. Of the more than -500 measurements tabulated in this repoft only a single determination was found that pertains directly to the hyperbaric environment (59). The discrepancies among different studies frequently exceeds a factor of 2. far too imprecise fbr most predictive work. The dearth of data is especially prominent for the peripheral tissues most at risk in hyperbaric exposures-i.e.. joints. ears, bones. and spinal cord-and fbr the gases most likely to be used-i.e.. nitrogen. helium. argon. and hydrogen.
Likes pinball1970
That all makes sense - the bends, of course! Thank you!
I've been reading a bunch of articles in this month's Scientific American on Alzheimer's and ran across this article in a web feed that I subscribe to. The SA articles that I've read so far have touched on issues with the blood-brain barrier but this appears to be a novel approach to the problem - fix the exit ramp and the brain clears out the plaques. https://www.sciencealert.com/new-alzheimers-treatment-clears-plaques-from-brains-of-mice-within-hours The original paper: Rapid amyloid-β...
https://www.discovermagazine.com/the-deadliest-spider-in-the-world-ends-lives-in-hours-but-its-venom-may-inspire-medical-miracles-48107 https://en.wikipedia.org/wiki/Versutoxin#Mechanism_behind_Neurotoxic_Properties https://www.sciencedirect.com/science/article/abs/pii/S0028390817301557 (subscription or purchase requred) The structure of versutoxin (δ-atracotoxin-Hv1) provides insights into the binding of site 3 neurotoxins to the voltage-gated sodium channel...
