infamous_Q
- 99
Ok. so say you have a fan that is moving air, at 1 atm, at about 10 m/s. what exactly happens to the pressure? does it change at all or...?
morry said:Well, according to Bernoulli, the faster a fluid flows, the lower the pressure. Does that answer your question?
When a fan is used, the air pressure in the surrounding area will decrease due to the movement of air caused by the fan.
The air pressure will decrease when a fan is turned on, as the fan blades cause air to move away from the fan, creating a low pressure area.
The speed of the fan directly affects the air pressure. The faster the fan is spinning, the lower the air pressure will be due to increased air movement.
Yes, the distance between the fan and an object will affect the air pressure. The closer the object is to the fan, the stronger the air movement will be, resulting in a lower air pressure.
No, a fan cannot create a true vacuum. However, it can create a low pressure area by moving air away from the fan, which can simulate a vacuum effect.
