What happens to the electrons in a Bose-Einstein Condensate?
In summary, when various atoms are turned into BEC's, their electrons are arranged in their standard atomic orbitals like at higher temperatures. The electrons are not free-floating around the entire condensate, but are still arranged into superconductive Cooper pairs. The individual nuclei in the condensate can get very close to each other, but they still feel the repulsion of the protons from each other. The range of interaction between the atoms in a BEC is shorter than a Coulomb interaction between charged particles. Cooper pairs are related to electrical superconductivity, but they are not needed in the theory of Bose-Einstein condensates. BEC's can only occur in a gas of particles with bosonic total spin, and they
bbbl67
217
TL;DR Summary
Do the electrons still orbit around the individual atomic nuclei?
When various atoms are turned into BEC's, are their electrons still arranged in their standard atomic orbitals like at higher temperatures? Or are the electrons free floating around the entire condensate? If the electrons are free-floating, then are they arranging themselves into superconductive Cooper Pairs? How close can the individual nuclei in the condensate get to each other? Do these nuclei still feel the repulsion of the protons from each other?
A BEC can be modeled simply by seeing the individual atoms as bosonic point particles, with some empirical interaction force between them. The interactions are of a shorter range than a Coulomb interaction between charged particles.
In other words, the internal structure of the atom is not very important here, but under those conditions it's very likely to just be in its electronic ground state.
How much shorter than the Coulomb range? 50% closer, more, less?
Two electrons, such as in a Cooper pair, can form a composite boson. A Helium-4 nucleus is also a composite boson. Both would be components of a Helium atom. So would He-4 nuclei and Cooper pairs, split apart and create two independent bosons that move through each other unimpeded?
Cooper pairs are not needed in the theory of Bose-Einstein condensates, they are related to electrical superconductivity.
The range being shorter than in Coulomb interaction means that the interaction force drops to zero faster than proportionally to the inverse square of distance, possibly exponentially, when going further away from the atom.
Likes bbbl67
The reason I brought up the Cooper pairs is because they seem to create a type of boson too, and both phenomena occur at near absolute zero. So it seemed plausible that BEC's and superconductivity are somehow related?
There are certain composite bosons that are neutrally charged, such as Tritium (2 neutrons, 1 proton, and 1 electron), which makes the whole atom bosonic. There are other kinds where only the nucleus is bosonic, like anything with an even numbers of protons plus neutrons. Do BEC's work only with the whole neutrally charged bosonic atom, or just bosonic nuclei is sufficient? A bosonic nucleus would feel a lot of electrical repulsion to other nuclei.
BEC comes about in the theory of weakly interacting gases of identical bosons. The superfluidity of helium-4 is probably related. But nuclei of atoms cannot Bose-condense.
Likes bbbl67
So fair to say that these condensates have an overlapping electron cloud, but not overlapping nuclei?
A typical BEC is prepared from a vapor of alkali metal atoms at very low pressure, where the atoms are typically far enough from each other to have little interaction between them. So the electron clouds of the individual atoms are really close to that of a single isolated atom in vacuum, but not exactly the same because there are some interactions.
Are BEC's in a gaseous form then? Looking at pictures of BEC's I always assumed that they might have been solid or liquid, because they looked more ordered.
The usual theory of BECs assumes that it's a very dilute gas of particles with bosonic total spin. The superfluidity of helium-4 is possibly somehow related to Bose-Einstein condensation, but it's not as simple because the atoms in liquid helium are close enough to their neighbors to interact a lot (and the electron clouds of the atoms are therefore also somewhat deformed from the shape they have in gas phase helium).
So liquid helium-4 and BEC helium-4 are different?
hilbert2 said:
I'm not sure what you mean with "BEC helium-4", but it seems that it's possible to attain Bose-Einstein condensation in a dilute gas of helium atoms put in an excited electronic state.
https://physicstoday.scitation.org/doi/full/10.1063/1.1381089
Yeah, earlier statement by @DrClaude that BEC's come from vapor, which implies gaseous state.
Liquid helium-4 and superfluid liquid helium-4 are different (there is a phase transition between the two). Superfluid helium-4 is probably a BEC, but you need to extend the theory of Bose condensation to describe it.
Is there a temperature barrier which turns it into a superfluid? As I understand it, for helium to be liquid it needs to be close to absolute zero. Does it need to be even closer to absolute zero to be a superfluid, or are there other factors?
Yes, it requires a temperature lower than melting point for liquid helium-4 to turn into a superfluid. If it's the helium-3 isotope, the temperature needs to be even lower. The mechanism of superfluidity is different for the two isotopes, because helium-3 atoms aren't bosons.
Likes bbbl67
Helium-4:
Helium-3:
The superfluid phase in 4He is akin to BEC. The superfluid phase in 3He is akin to superconductivity with the formation of Cooper pairs, hence the much lower temperature.
Likes bbbl67
DrClaude said:
Helium-4:
Helium-3:
There is actually a solid phase for Helium?
I think it's possible to make anything become some kind of a solid with high enough pressure and low temperature. A liquid phase doesn't necessarily exist at all pressures, for instance carbon dioxide condenses directly to a solid if you cool it down at atmospheric pressure.
Likes DrClaude and bbbl67
FAQ: What happens to the electrons in a Bose-Einstein Condensate?
What is a Bose-Einstein Condensate?
A Bose-Einstein Condensate (BEC) is a state of matter that occurs when a group of bosons, or particles with integer spin, are cooled to near absolute zero (-273.15 degrees Celsius). In this state, the particles lose their individual identities and become indistinguishable from one another, behaving as a single entity.
In a Bose-Einstein Condensate, the electrons behave as waves rather than particles. They occupy the same quantum state and move in a coordinated manner, resulting in a superfluid state with zero viscosity.
How are Bose-Einstein Condensates created?
Bose-Einstein Condensates are created by cooling a gas of bosons to extremely low temperatures using methods such as laser cooling or evaporative cooling. As the temperature decreases, the bosons lose their kinetic energy and begin to occupy the same quantum state, forming a BEC.
What are the potential applications of Bose-Einstein Condensates?
Bose-Einstein Condensates have potential applications in fields such as quantum computing, precision measurements, and the study of fundamental physics. They can also be used to simulate and study complex quantum systems that are difficult to observe in traditional matter.
Can Bose-Einstein Condensates exist in nature?
Bose-Einstein Condensates can exist in nature, but they are typically only observed in highly controlled laboratory settings due to the extreme conditions required for their formation. However, some researchers believe that BECs may have played a role in the early universe and could potentially exist in certain astrophysical environments such as neutron stars.
