What happens to the pressure change inside a rising balloon?
In summary: The balloon has a vast envelope that's only partially filled at sea level. By the time it is at a design height of several tens of km, the Helium inside has expanded and the envelope is more or less spherical.
axer
35
Hello, so i have a question regarding the pressure change inside a rising hydrogen balloon,
I know that the pressure change of air outside is decreasing(as we go up = less pressure)
And as the balloon is rising it's increasing its volume.
but what happens do the pressure change inside the balloon as it rises? decreses or increases?
Constant mass, increasing volume means what?
according to Boyle's law increasing volume means deceasing pressure,..
But can it be possible to have a decrease in the change in pressure both inside and outside?
Why not? What actually causes the change of pressure/volume inside if the envelope is loose?
I didn't quite understand what you meant. P = 1/V is based on a constant T..
I don't mean equations, I mean objects/concepts. You have a balloon. It expands. Why?
If this were a party balloon at home on your birthday, you would answer "the balloon expands because I am blowing air into it." Does that happen here? If not, what physically is happening?
my explanation is that because the difference in pressure above is low therefore the volume of the balloon is increasing.
Other explanation is that because the volume of the air above is increasing, therefore the volume of the balloon is.. V(object)=V(air)
I don't know.. please tell me in your understandings
There might be a language issue here, so fist a minor edit/correction of your wording:
..."the difference in pressure above is low therefore the volume of the balloon is increasing."
That has extra words in it. You should simply say that:
"as the balloon rises, the pressure of the air around it decreases."
Is that what you meant?
Yes, i meant this.
axer said:
Yes, i meant this.
...and if the pressure of the air around the balloon is decreasing, then the balloon will have a higher pressure than the air around it...unless it too expands.
ooh, ok i think I got it, since the balloon is increasing in volume, therefore the pressure is decreasing. Ok thanks!
Likes davenn and russ_watters
You have to remember that any 'serious' balloon (like a meteorological ballon) has a vast envelope that's only partially filled at sea level. By the time it is at a design height of several tens of km, the Helium inside has expanded and the envelope is more or less spherical. It's not a good idea to use a balloon with an elastic membrane that's under tension at low level because it will stop rising if the gas inside is constrained by the envelope - no lifting power.
Related to What happens to the pressure change inside a rising balloon?
1. What causes the pressure change inside a rising balloon?
The pressure change inside a rising balloon is caused by the change in the volume of gas inside the balloon. As the balloon rises, the atmospheric pressure decreases, causing the gas inside the balloon to expand and increase in volume. This increase in volume leads to a decrease in pressure inside the balloon.
2. How does the pressure change affect the size of the balloon?
The pressure change inside a rising balloon affects the size of the balloon by causing it to expand. As the pressure inside the balloon decreases, the gas molecules are able to spread out and take up more space, increasing the size of the balloon.
3. Does the pressure inside the balloon continue to decrease as it rises?
Yes, the pressure inside the balloon will continue to decrease as it rises, as long as the atmospheric pressure remains lower than the pressure inside the balloon. This is because the gas inside the balloon will continue to expand to fill the available space.
4. How does the temperature affect the pressure change inside a rising balloon?
The temperature can affect the pressure change inside a rising balloon by affecting the volume of gas inside the balloon. As the temperature decreases, the gas molecules will have less energy and move slower, causing a decrease in volume and an increase in pressure inside the balloon.
5. What happens to the pressure change inside a rising balloon once it reaches a certain height?
Once a balloon reaches a certain height, the pressure inside will equalize with the atmospheric pressure, resulting in no further pressure change. This is because the gas molecules inside the balloon will have expanded to the point where they are no longer compressed by the lower atmospheric pressure.
15K
  • Mechanics
9K
  • Mechanics
29K
