What happens to the sound wave?
In summary, the conversation discusses what happens to a sound wave after it hits the eardrum. The speaker found information on how the sound wave interacts with the ear, but there was no information on whether the wave continues or if there is any energy left. The experts suggest that the sound wave continues deeper into the brain but quickly attenuates and is converted to heat. Some energy is used to generate nerve impulses, while the rest ends up as heat. The conversation also touches on the role of the ossicles and the cochlea in matching the sound wave and transferring energy to the inner ear. They also mention the importance of matching in communication equipment to improve signal to noise ratio.
omega-centauri
Ok so it happened again... my students asked a question I hand't thought of before (love it when that happens!) Can you help me?
What happens to the sound wave after it hits the eardrum? Does it get absorbed, or does it continue to go through your head?
I found lots of info about how the sound wave interacts with the ear, but then there's no info on if the wave continues after vibrating the ear drum (is there any energy left?) Any ideas are appreciated!
I guess the soundwave continues deeper into the brain but it should attenuate fast and converted to heat. The portion of the soundwave that passes through the ear hole is very small and thus has very small energy (unless we talking for a soundwave of very big intensity/energy density, something like >150dB) and cannot damage the ear drum or the brain.
It's essentially all absorbed. Some of the energy in the energy in the wave goes to wiggling the little fibers in the inner ear to generate the nerve impulses that our brains interpret as sound. The rest of the energy ends up (as with just about all absorbed energy) as random bouncing around of the atoms in our heads, which is to say heat; the total amount of energy is so small that the amount of heat involved is completely unnoticeable.
. . . and some will be reflected, n'est-ce pas?
Attached to the ear drum is a triad of tiny bones (the ossicles) which are essentially, levers. They are the equivalent of 'gears' or a transformer (in an acoustic sense) and they match the sound to another 'drum' on at the entrance to the inner ear. The sound vibrations are passed through all this mechanism and the matching network just described, ensures that a good amount of the sound energy gets transferred to the cochlea (a spiral of nerves attached to tiny hairs, each of which vibrates according to the frequencies contained in the incoming sound.
Matching is used throughout communications equipment and it takes many different forms, depending on what particular medium is being used. It's always a matter of improving the Signal to Noise Ratio as much as possible.
Oh yes. There's always some degree of mis-match. (Fish and Whales have an easier job because the sound in water is already at a similar impedance to the sound in their wet tissues.)
FAQ: What happens to the sound wave?
1. What is a sound wave?
A sound wave is a type of mechanical wave that travels through a medium, such as air or water, as a series of compressions and rarefactions. It is created by the vibration of an object, such as a guitar string or vocal cords, and can be detected by the eardrum.
2. How does a sound wave travel?
A sound wave travels by causing particles in the medium to vibrate, creating a series of compressions and rarefactions. This vibration is transmitted through the medium in all directions, allowing the sound to travel to our ears or other detection devices.
3. What happens to a sound wave when it reaches a new medium?
When a sound wave reaches a new medium, it can either continue to travel through the medium or be reflected or absorbed. This depends on the properties of the new medium, such as its density and elasticity.
4. How does the frequency of a sound wave affect its pitch?
The frequency of a sound wave is directly related to its pitch. Higher frequency sound waves have a higher pitch, while lower frequency sound waves have a lower pitch. This is because the frequency determines the speed at which the particles in the medium vibrate, which our ears perceive as pitch.
5. What happens to a sound wave when it encounters an obstacle?
When a sound wave encounters an obstacle, it can be reflected, refracted, or diffracted. Reflection occurs when the sound wave bounces off the obstacle, while refraction occurs when the sound wave changes direction as it passes through the obstacle. Diffraction occurs when the sound wave bends around the obstacle, causing it to spread out.
