What happens to wavefunction if you swap electrons?
In summary, swapping two electrons in a multi-electron atom results in a change in the wavefunction due to antisymmetry. The symmetric-antisymmetric concept can be explained using a simple example in path integral formulation, where the amplitude for a process involving fermions is zero if the detectors are the same, but nonzero if they are different.
Kara386
208
If you have a multi-electron atom and you swap two electrons around, what happens to the wavefunction? I think nothing happens because electrons are identical, but then they can have different spins, so would the wavefunction change if you swapped a spin up electron with a spin down one?
How do you propose to "swap" the electrons?
I have no idea, it's a good question that I hadn't considered. Because isn't that what the whole symmetric-antisymmetric thing is about? It was explained to me in terms of swapping electrons, having some permutation of a pair, and I didn't really understand it so I thought I'd ask here! :)
I may have completely misunderstood...
Sort of. Perhaps a concrete example will help. It actually works better as a simple example to think of things in the path integral formulation, rather than wave functions.
Suppose we run an experiment in which two particles get emitted from two different sources, and some time later two particles get detected by two different detectors. To keep things simple, we'll assume that the particles have the same spin throughout the experiment (because we've prepared them with the same spin and the apparatus doesn't change the spin), so we only need to consider their positions. We label the sources as S1 and S2, and the detectors as D1 and D2. Then the path integral that describes this process (leaving out all the higher order terms that arise in quantum field theory when we include virtual particles) will have two terms:
Term 1: a particle goes from S1 to D1, and a particle goes from S2 to D2.
Term 2: a particle goes from S1 to D2, and a particle goes from S2 to D1.
Now we can state "the symmetric-antisymmetric thing" easily: if the particles are bosons (symmetric), Term 1 and Term 2 have the same sign; but if the particles are fermions (antisymmetric, like electrons), Term 1 and Term 2 have opposite signs.
Note that, if D1 and D2 are the same, then for fermions the amplitude for this process is zero: both terms have the same magnitude (can you see why?), and opposite sign, so they cancel. This is the familiar Pauli exclusion principle. But if D1 and D2 are not the same, then the terms won't exactly cancel, because the distances will be slightly different, so there will still be a nonzero amplitude for this process to happen--but it will be smaller than in the case of bosons, where the amplitudes are the same sign.
Likes Kara386, Nugatory and Vanadium 50
The wave function changes sign because of antisymmetry. That's all.
Likes newjerseyrunner and Kara386
FAQ: What happens to wavefunction if you swap electrons?
What is a wavefunction?
A wavefunction is a mathematical description of the quantum state of a particle, which includes information about its position, momentum, and spin.
What does it mean to swap electrons?
Swapping electrons refers to the exchange of two electrons between two particles. This can happen in certain quantum processes, such as electron-electron scattering.
Does swapping electrons affect the wavefunction?
Yes, swapping electrons causes a change in the wavefunction of the particles involved. This is because the wavefunction is a representation of the quantum state, and exchanging particles changes the state.
How does swapping electrons affect the properties of the particles?
Swapping electrons can change the properties of the particles, such as their position, momentum, or spin. This is because the wavefunction is directly related to these properties, so a change in the wavefunction leads to a change in the properties.
Are there any practical applications of swapping electrons and studying the wavefunction?
Yes, understanding the effects of swapping electrons and how it affects the wavefunction is crucial in many areas of quantum physics, such as quantum computing and quantum chemistry. It also helps to explain the behavior of particles in various physical processes.
