I What happens when gas is combusted while moving?
When combustible gas mixtures like O2 and H2 combust while already in motion, their initial velocity contributes to the overall velocity of the combustion products. The principle of momentum conservation dictates that the center of mass of the gas cloud retains its motion, allowing for continued thrust even at speeds exceeding the exhaust velocity. This means that the combustion process does not negate the pre-existing velocity of the gas. However, the effective acceleration depends on the amount of propellant that has already been accelerated by prior combustion. Understanding these dynamics is crucial for applications like rocket propulsion.
Limebat
If a combustible gas mixture (say O2 and H2 are combusted to form H2O) are already moving before combustion, what would happen? Intuition tells me the previous velocity (say the gas was moving 150 feet per second) would just add to the velocity achieved when standing still and then combusted (say a few kilometers per second). Basically, net velocity. However, I haven't taken classic thermodynamics, so I am unsure and would like to double check with others.
If the gas cloud is not interacting with anything else, its center of mass will retain its motion, due to momentum conservation.
Likes Lnewqban, Limebat, jbriggs444 and 1 other person
This is why a rocket motor can continue to produce thrust even when accelerating to faster than the exhaust velocity of the fuel. Of course all the remaining propellant has to have been accelerated up to speed by the fuel previously burned, so there is no "free lunch"
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
