- #36
PeterDonis
Mentor
- 47,685
- 23,929
Spin-Analyser said:At the very least they would create an optic boom from there own light as they break the light barrier.
They can't "break the light barrier"; nothing can go faster than light. It's true that the correct formulation of that rule is more complicated in curved spacetime, but none of the complications make an "optic boom" possible.
(It's also true that in a material medium, something like an "optic boom" is possible, when objects travel faster than the speed of light in the medium, which can be slower than the speed of light in vacuum. This is called Cerenkov radiation. But here we're talking about vacuum and the speed of light in vacuum, so none of that applies.)
Spin-Analyser said:In the case of a small super massive black hole near the end of its life with lots of light from all the matter that had ever crossed the event horizon anywhere near that side of the black hole piling up in front of the event horizon, a falling object wouldn't see the light waves building up but would see a blinding flash when reaching the event horizon
Yes, this is correct, but it is not a "local" phenomenon. See below.
Spin-Analyser said:and then everything would be pitch black because no light from further in can reach them.
But light from further out still can, so it wouldn't be pitch black. It's true that the light coming in would be distorted, but again, that's not a "local" phenomenon, because the light has to come from distant locations to be distorted. Light from locations close to the infalling observer is not distorted, and the infalling observer can't tell from it that he is at or inside the horizon.
Spin-Analyser said:That contradicts the idea that nothing special happens locally for a falling object when crossing the event horizon.
No, it doesn't. I already explained why: all the light in the "blinding flash" was built up at the horizon over a long period of time. That is not a "local" phenomenon; it requires the horizon and the hole to exist for a long period of time. "Local" means local in space *and* time. The same goes for the other items above, such as light coming in from distant locations being distorted--they're not local because they require a large extent of space, or a long period of time, or both. Your repetition of incorrect statements after they've already been corrected is part of what got your last thread locked.
