What has radio got to do with this activity?
In summary: Hello Vanadium,This is a really good question. Basically, scientists measure the emission of an element over time and use that data to calculate the half life.
SpY]
65
what has "radio" got to do with this activity?
Probably sounds silly, but what has "radio" got to do with this activity?
I don't know if I'm interpreting this guy's formula right (http://www.hps.org/publicinformation/ate/q8270.html) so can someone confirm this expression for half life:
[tex]A= \frac{C_R}{CD}[/tex]
[tex]=kN[/tex]
[tex]= \Bigg( \frac{ln(2)}{T_\frac{1}{2}} \Bigg) \Bigg( \frac{m_0}{A_r} N_A \Bigg) [/tex]
Where [tex]C_R[/tex] is the count rate, [tex] C_D [/tex] the counts per disintegration, k the decay constant, N the number of radioactive atoms, [tex]T_\frac{1}{2} [/tex] the half life, [tex]m_0 [/tex] the original mass of the pure substance [tex] A_R [/tex]the atomic weight [tex] N_A [/tex] Avogadro's number. (bad latex sorry)
If not, can you help me find a way to find the half life of a long lived radionuclide?
Hi there,
This equation seems right. Is your problem lies in understanding the meaning of it. If so, I can try to walk you through it.
[tex]C_R[/tex] is the number of alpha particles detected per minute.
[tex]C_D[/tex] is the efficiency of your detector -- the number of disintegration compared to the number particles detected.
By dividing these two numbers, we obtain the number of disintegration in the last time interval, or the activity of the sample.
Coming back to the basic equation of radioactive disintegration:
[tex]dN = \lambda N dt[/tex]
where dN is the number of disintegration per time interval of a sample (activity): dN = A, [tex]\lambda[/tex] is the decay rate: [tex]\lambda = \frac{ln 2}{T_{1/2}}[/tex], N is the number of unstable nuclei in the sample. A bit more about this last parameter.
We have a sample with [tex]4.41 \times 10^{-3}g[/tex] of U238. We need to find how many nuclei this mass represents. And for this we need to find the amount of moles in the sample:
[tex]\frac{m}{238.03g/mol}[/tex]
With this number, we can find out the number of atoms in the system:
[tex]\frac{m}{238.03g/mol} \cdot N_A[/tex]
You then need to isolate the half life variable in the equation, and it is as simple as that.
Hope this helps. Cheers
ye thanks it does help, was unsure about my formula and what Cr was
But one thing is how they actually determine BILLIONS of years as half-life: how long would they have to monitor the decay of a sample just to plot the first few points of this curve? Or would that matter? Cos I was guessing the more points (count values), the more accurate exponential fit, the more accurate half-life extrapolation is
Hi there,
I don't think I understand your question very well. If you would put this sample on this detector, it would count 1014 alpha particles per minute. The only thing is that if you want to measure some kind of "decrease" in the activity (or count rate), you would have to wait a very long time.
Cheers
Yes, that's what I'm asking, if you have a half life of billions of years, how long would you have to wait for a decrease? And then measure enough decreases to get an exponential curve (to predict the HL)
You don't need to see the decrease - you know how fast it's decaying by seeing how much it emits.
Hi there,
I see your point. Well knowing that every measurement, even over many many hours, will have a certain uncertainty. From what I remember, for alpha measurement uncertainty in environmental radiation is in the order of a few %. Therefore, to measure an effective decrease of counts per minutes (of 25%), you would have to wait a couple of millions of years.
Cheers
Vanadium, I don't understand how you can observe a decrease by just taking one value on how much it emits.
This is exactly my question, if something has a HL of BILLIONS of years, how long do they have to observe the element to notice a decay? Otherwise, how do they even find the HL of such an element :O
Related to What has radio got to do with this activity?
What is radio?
Radio is a form of wireless communication that uses electromagnetic waves to transmit information, such as sound or data, through the air. It is commonly used for broadcasting audio and is a vital tool in modern communication systems.
How does radio work?
Radio works by converting sound waves into electromagnetic waves, which are then transmitted through the air. These waves are picked up by a receiver and converted back into sound waves, allowing us to hear audio broadcasts.
What are the applications of radio?
Radio has a wide range of applications, including broadcasting audio, communication between two or more people, navigation systems, and remote control devices. It is also used in industries such as aviation, military, and emergency services.
How is radio used in this particular activity?
The use of radio in this activity may vary, but it could be used for communication between team members, broadcasting instructions or updates, or even as a means of navigation or tracking.
What are the advantages of using radio in this activity?
The use of radio in this activity allows for wireless communication, which can be crucial in certain situations. It also allows for real-time communication and can reach a wide range of distances, making it a reliable and efficient tool for many activities.
