What incident energy is required to ionize a helium atom?
In summary: OK, I'll try to do that. (There's a little inconsistency here: You said "m" in the formula "E2=p2c2+m02c4 (m0 is the rest mass)" means the moving mass, but you said "m" in my formula "T = mc2(γ - 1)" means the rest mass. Which is which?)I'll email you the Science article. But I'll also post here what I learn, so others can see it too.I'll start with the proton-proton collision case, since it's simpler. But with that, I'm not sure what you want me to do. You said "Try to derive the relation between the final
davidpotts
The energy required to ionize a helium atom is 24.6 eV. If helium gas is bombarded with charged particles, at what incident energy will ionization of helium just be observed if the projectiles are (a) alpha particles (b) protons (c) electrons?
Most of the exercises in this chapter have to do with conservation of momentum and energy, but otherwise I really don't know what equations would be relevant.
I need help knowing even where to begin with this. It seems like the entire kinetic energy (which I assume = "incident energy") of the incoming particle should go into the ionization, with the result that the total kinetic energy of the system after the collision = 0 and the helium atom is ionized. This would imply that the incident energy required is 24.6 eV and that the same amount is required regardless of what sort of particle is the projectile. But this is wrong. Hint please?
Consider the process as inelastic collision. You can assume that after leaving the helium atom, the speed of the electron is zero.
ehild
ehild
Yeah, I figured this one out. (Sorry, I suppose I should've posted something.) The trick is that since the total energy before the collision, Ei, which is the kinetic energy of the incoming particle, should be just enough to cause the ionization of the helium atom, we can assume it is as low as it can be consistent with conservation of momentum. I.e., the collision is perfectly inelastic and Ei is low enough to preserve conservation of momentum and have just enough left over to ionize the helium, i.e., 24.6 eV.
So we have for conservation of energy:
Ei = Ef
.5mVi2 = .5(m + H)Vf2 + 24.6 eV
where m is the mass of the incoming particle and H is the mass of the helium atom.
For conservation of momentum:
Pi = Pf
mVi = (m + H)Vf
Vf = Vi(m/m + H)
So:
.5mVi2 = .5(m + H)[m/(m + H)]2Vi2 + 24.6eV
.5mVi2[1 - m/(m + H)] = 24.6eV
Solve for .5mVi2 in the three cases where:
H = m
H = 4m
H + m ≈ H
The problem I could really use help with is the one on very high speed proton-proton collisions: https://www.physicsforums.com/showthread.php?t=526305
I tried treating it like the above only using relativistic formulas instead of nonrelativistic. But that didn't work. I doubt that any of the problems in this introductory book I'm using could really be very hard, but it may be that in this proton-proton case there's something a little out of the ordinary. The book, published in 1964, cites a reference for this problem: G. K. O'Neil, Science 141: 679 (1963). I don't have easy access to this journal or I might just look up the article.
Apply conservation of momentum and determine the energy after collision. You can use the relation between the momentum and energy: E2=p2c2+m02c4 (m0 is the rest mass)
ehild
ehild
So is the idea the following?
Compute the initial kinetic energy from T = mc2(γ - 1). So
3 GeV = 938(γ - 1) MeV (.001 GeV/MeV)
2.062 = .938γ
γ = 2.1983
So
1/(1 - V2/c2).5 = 2.1983
1 - V2/c2 = .2069
V = .89c
Now use conservation of momentum.
Pi = Pf
mγV = Pf
938(2.1983).89c = Pf
1836.3/c = Pf
Now if the collision is inelastic and no initial energy is absorbed into producing other particles, the initial total mass = the final total mass. So
Ef2 = Pf2c2 + [(2)(mc2)]2
Ef2 = (1836.3/c)2c2 + [(2)(938)]2
Ef2 = 3,372,000 MeV + 3,519,376 MeV
Ef = 2.625 GeV
Ei = Ti + mc2
Ei = 3 GeV + .938 GeV
So the fraction of the energy of the moving proton not available for inelastic interactions in this proton-proton collision is
2.625/3.938 = .6666
The answer the book gives is .6, which I don't think is close enough to be due to rounding error.
The main problem I see here is that I'm comparing Ef based on two protons with Ei based on one. But I don't know what help there is for it. Pi is based on one proton, Pf on two. And I can't just use Ei = 3 GeV + (2)(.938) GeV, since what we need is the energy of the moving proton alone.
Take care what you denote by m. In the formula I wrote in my post, m means the moving mass, m=m0γ. Recalculate the problem with that.
ehild
ehild
Sorry, but I'm not getting you. Your formula was: "E2=p2c2+m02c4 (m0 is the rest mass)". And my formulas all use "m" for rest mass, multiplying by γ where needed. What am I doing wrong?
I got that Science article by the way. I'll read through it tomorrow and see if I can see what's up.
I am sorry... I got confused with the notations. You are right, it is the rest mass in the formula E2=p2c2+m02c4, which you denoted by m.
Try to derive the relation between the final KE and the generator energy instead of calculating with numbers from the beginning. You get the momentum of the accelerated proton from the formula above, using E=m0c2+E(generator). No need to calculate the speed.
And let me know, what you learned from the Science article.
I got the formula from Giancoli: Physics for Scientist and Engineers.
ehild
I have found a mistake at the beginning of your derivation:
2.062 = .938γ
0.938 γ= 3+0.938 .
ehild
ehild
Ahh! Much quicker technique. And it gets the same answer as I was getting with my more laborious technique (after correcting the boo-boo you found, and thanks for that).
The Science article doesn't provide much illumination beyond explaining why one would be interested in this sort of problem. It seems that at the time the article was written, particle accelerators typically accelerated a particle toward a stationary target particle, thereby wasting a considerable amount of kinetic energy in conserving momentum. At nonrelativistic speeds, a perfectly inelastic collision wastes half the initial kinetic energy this way. At relativistic speeds, the waste is considerably greater, and that is the point of the exercise. But the article doesn't explain how to calculate the amount of relativistic kinetic energy that is taken up conserving momentum; it only gives a table showing the amounts for various accelerators that were in operation at the time. Calculating these amounts is left as an exercise for the student! Literally.
So here's how I think it must go.
Eproton = Ti + mc2
Eproton = 3 + .938
Eproton = 3.938 GeV
Eproton2 = pi2c2 + (mc2)2
3.9382 = pi2c2 + .9382
pi2c2 = 14.628
pi = 3.825/c
The total initial energy is:
Ei = Ti + (2)mc2
Ei = 3 + (2)(.938)
Ei = 4.876 GeV
Now Ei = Ef and pi = pf. So the "Remainder Energy" (which could be rest energy of whatever particles exist after collision, radiation energy, etc.) after the collision that is not taken up conserving momentum is:
Ef2 = (pf/c)2c2 + RE2
4.8762 = 3.8252 + RE2
RE = 3.024 GeV
Therefore, the kinetic energy after the collision is:
Tf = Ef - RE = 4.876 - 3.024 = 1.85 GeV
As a proportion of the initial kinetic energy, this is:
1.85/3 = .617
The chart in the article (reproduced for this exercise in my special relativity textbook) gives a value of .60. It bothers me to think there could be this much rounding error, but I don't know what else to think.
The values provided versus what I compute are:
Accelerator energy / Loss due to COM (published) / Loss due to COM (computed by me)
3 / .60 / .62
7 / .72 / .69
25 / .80 / .79
200 / .92 / .91
1000 / .96 / .96
There is a follow-up exercise. The article suggests that the lost kinetic energy can be recovered by building an accelerator that shoots opposing beams of protons at each other instead of shooting one beam of protons at a stationary mass. Thus, for example, if each beam is accelerated at 3 GeV, the total initial kinetic energy will be 6 GeV instead of 3 GeV, and since the total pi of the opposed protons is 0, the total pf must also be 0 and there should be no energy lost conserving momentum; it can all go into inelastic interactions.
The task we are given is to find the energy an old model, stationary target accelerator would require to produce the same amount of energy available for inelastic interactions as a new model opposing beam accelerator where each beam has an energy of (a) 3 GeV (b) 25 GeV (c) 31 GeV.
So suppose that the energy in each beam of a colliding beam accelerator is 3 GeV. Then the total initial energy is:
Ei = 2(Ti + mc2)
Ei = 2(3.938) = 7.876 GeV
And since pf = pi = 0, kinetic energy after collision is 0 and all of Ef = Ei is available for inelastic interactions. This is what we called RE in the above, stationary target case. Using the above formulas, we need to solve for the initial Ti of the single, moving proton that will produce the same Ef as we just found in the colliding beam case.
We have:
Eproton = Ti + mc2
Ei = Ti + (2)mc2
Bearing in mind that Ef = Ei and pf = pi, we can rewrite the first equation as:
Ei2 = (pi/c)2c2 + RE2
We know RE and mc2, so the four equations become:
Ei2 = (pi/c)2c2 + 7.8762
Eproton2 = pi2c2 + .9382
Eproton = Ti + .938
Ei = Ti + (2).938
Thus, we have four equations and four unknowns. We solve for Ti:
Ti(2).938 + [(2).938]2 = 7.8762
Ti = 31.19 GeV
The value published in the Science article is 31 GeV. The table published in the article versus the values I computed are:
Colliding beam energy / Single beam energy (published) / Single beam energy (computed by me)
3 / 31 / 31.19
25 / 1360 / 1432.62
31 / 2040 / 2173.04
Again, the discrepancy between the published values and what I'm getting bothers me, but I don't know what to do about it. Anyway, the energy savings achieved by the colliding beam technique are very impressive!
Your derivation looks good. I do not know what can be the reason of the differences between your results and those of the book. I asked an other member in the Forums, and he also thinks it correct.
There is some flaw, but only in the notation: do not write (p/c)2c2 when you mean p2c2.
To check rounding errors, derive the "not usable amount of energy" symbolically, in terms of the generator energy and rest proton mass, and substitute data at the end.
If you find a reliable solution, please let me know.
ehild
ehild
Yes, I see now that I shouldn't have expressed a general formula that way.
Another mistake is that "we need to solve for the initial Ti of the single, moving proton that will produce the same Ef as we just found in the colliding beam case" should read "...that will produce an RE of the same magnitude as the Ef we just found in the colliding beam case."
Thanks again for your help with this!
Related to What incident energy is required to ionize a helium atom?
1. What is incident energy?
Incident energy refers to the amount of energy that is transferred to an atom or molecule during a collision or interaction with another particle or electromagnetic radiation.
2. How is incident energy measured?
Incident energy is typically measured in units of electron volts (eV) or joules (J).
3. How does incident energy affect an atom?
When an atom is exposed to incident energy, it can cause electrons in the atom to become excited or even ionized (where an electron is completely removed from the atom). The amount of incident energy needed to ionize an atom depends on the atom's size, structure, and energy levels.
4. What is the incident energy required to ionize a helium atom?
The incident energy required to ionize a helium atom is 24.6 eV. This is the minimum amount of energy needed to remove one of the two electrons from a helium atom, resulting in a helium ion (He+).
5. Why is the incident energy required to ionize a helium atom important?
Knowing the incident energy required to ionize a helium atom is important in understanding the properties and behaviors of atoms and molecules. It also has practical applications in fields such as physics, chemistry, and engineering.
  • Sticky
  • Atomic and Condensed Matter
