MHB What initial velocity is needed to reach the top of the Washington Monument?
  • Thread starter Thread starter karush
    Ground Velocity
To reach the top of the Washington Monument, an object must be thrown upward with an initial velocity of approximately 187.62 ft/sec. The motion can be modeled using the equation f(t) = -16t^2 + V_0t, where V_0 is the initial velocity. At maximum height, the velocity becomes zero, leading to the equation V_0 = 32t. By solving for t when the height is 550 ft, it is determined that t is approximately 5.86 seconds. The discussion also mentions an alternative approach using energy conservation, equating kinetic energy to gravitational potential energy to find the initial velocity.
karush
MHB
With what initial velocity must an object be thrown upward (from ground level) to reach the top of the Washington Monument (approximately $550$ft.)
well since $f(t)=-16t^2+V_0 t+S_0$ then $550=f(t)$
also, that $f'(0)=V_0$ and $f''(t)=-32$
this is supposed to be solved by using integration but I don't see how this is done without knowing what $t$ is. any suggest?
answer is $187.617\frac{ft}{sec}$
With $\displaystyle S_0=0$ we have:
$\displaystyle f(t)=-16t^2+v_0t$ and so:
$\displaystyle f'(t)=-32t+v_0$
What values do the function and its derivative have when the object has reached its desired maximum height?
well the object has $0$ velocity when it reaches max height and since $f'$ is the velocity
we set $0=-32t+V_0$ or $V_0=32t$ but still we have $t$ in this so am going the right direction,
Yes, you are doing well, now what is the value of $\displaystyle f(t)$ when the object reaches the maximum height?
max height is given at $550ft$ so $550=-16t^2+(32t)t=32t$ so then $t=5.86$
don't see how this helps if this is plugged back in anywhere(Speechless)
This gives you:
$\displaystyle -16t^2+32t^2=16t^2=550$
Solve this for t, then use this value in the formula you found for initial velocity as a function of t.
I know you are to solve this dynamically, but you could also use energy considerations, i.e, equate the initial kinetic energy to the final gravitational potential energy:
$\displaystyle \frac{1}{2}mv_0^2=mgh$
$\displaystyle v_0=\sqrt{32\cdot550}=40\sqrt{22}\,\frac{\text{ft}}{\text{s}}$
appreciate the help, now I see what is happening:cool:
well from the TI-nspire I got
$solve(-16t+vt=550,v) v=187.62 ft/s$ where $t=5.86$
  • · Replies 36 ·
