What integer makes $(x-a)(x-10) +1$ factorable as $(x+b)(x+ c)$?
  • MHB
  • Thread starter kaliprasad
  • Tags
    Expression
In summary: Not a solution but resolving query. you should provide the methodabove is a good ans and completely different from solution below
kaliprasad
MHB
1,335
find integer a such that $(x-a)(x-10) +1$ can be factored as $(x+b)(x+ c)$ where b and c are integers
Mathematics news on Phys.org
$\displaystyle \begin{align*} \left( x - a \right) \left( x - 10 \right) + 1 &= \left( x + b \right) \left( x + c \right) \\ x^2 - 10x - a\,x + 10a + 1 &= x^2 + c\,x + b\,x + b\,c \\ x^2 - \left( 10 + a \right) x + 10a + 1 &= x^2 + \left( b + c \right) x + b\,c \end{align*}$
So equating the coefficients gives $\displaystyle \begin{align*} - \left( 10 + a \right) = b + c \end{align*}$ and $\displaystyle \begin{align*} 10a + 1 = b\,c \end{align*}$. See what you can do from here.
Hi Prove It,(Smile)
This problem is meant to be a challenge and thus, it deserves a fully well explained solution. But I understand that you have been posting quite much help at this site recently that it might be just the case that you didn't aware this problem comes from the Challenge Problems sub-forum.:)
anemone said:
Hi Prove It,(Smile)
Yes I should look at what forum these questions are in hahaha.
Hi kaliprasad,
Thanks for posting another great math challenge at MHB, I deeply appreciate that.
For this challenge, I was wondering if there are (finitely) many values for $a$ that meet the condition of the problem? Also, if $b$ and $c$ meant to be distinct integer? If they are not, then I can tell $a=8$ is a valid solution though.:)
anemone said:
Hi kaliprasad,
1) there are more than 1
2) b and c may be same
3) finite number of solutions
$$(x-a)(x-10)+1=x^2-(10+a)x+10a+1$$
Since we need to resolve the above into two linear factors, the discriminant must be greater than or equal to zero i.e
$$(10+a)^2-4\cdot (10a+1) \geq 0 \Rightarrow a^2-20a+96 \geq 0$$
$$\Rightarrow (a-12)(a-8) \geq 0$$
Also, the discriminant must be a perfect square i.e
$$(a-12)(a-8)=m^2$$
where $m$ is some integer. Substitute $a-10=t$.
$$\Rightarrow t^2=2^2+m^2$$
Clearly, $m=0$ i.e $\boxed{a=8,12}$.
$$(a-12)(a-8)=m^2$$
as $(x-a)(x-10)+ 1 = (x+b)(x+c)$
Putting $x = -b$ we get
$(-a-b)(-b-10) + 1=0$ or
$(a+b)(b+10) = -1$
This implies $(a+b) = 1$ and $b+ 10 = - 1$ or $b = -11\, a = 12$
Or $a+b = -1$ and $b + 10 = 1$ => $b = -9\, a = 8$
hence a = 8 or 12
because of symmetry nature of RHS we need not put x = c
FAQ: What integer makes $(x-a)(x-10) +1$ factorable as $(x+b)(x+ c)$?
What is factorizing an expression?
Factorizing an expression is the process of breaking down a mathematical expression into smaller factors that can be multiplied together to get the original expression. It is a fundamental concept in algebra and is used to simplify and solve equations.
Why is factorizing important in math?
Factorizing is important in math because it allows us to simplify complex expressions, making them easier to work with. It also helps us to solve equations and identify patterns in mathematical relationships.
How do you factorize an expression?
The first step in factorizing an expression is to look for common factors that can be factored out. Then, use techniques such as grouping, difference of squares, or trial and error to factor the remaining expression. It may take some practice and trial and error to factor an expression correctly.
What is the difference between factoring and expanding an expression?
Factoring and expanding are inverse operations. Factoring involves breaking down an expression into smaller factors, while expanding involves multiplying out the factors to get the original expression. Expanding is the reverse of factoring, and both are important in simplifying and solving equations.
What are some real-life applications of factorizing?
Factorizing is used in many real-life applications, such as simplifying fractions, finding common denominators, and solving equations in physics and engineering. It is also used in financial analysis to simplify complex financial equations and identify patterns in data.
