Exploring the Origins of 4π in Coulomb's Constant
  • Thread starter yaseen shah
  • Tags
    Constant
In summary, Coulomb's constant in his law is written as 1/4πε0, where the factor of 4π is included in order to avoid extra factors in Maxwell's equations. This constant can also be written as a straightforward constant (k) but using the second form makes calculations easier in most problems. The 4π in the constant is related to the unit sphere area and comes from Gauss's Law, where the flux of electric field is proportional to the charge inside a closed surface. This choice of constant is based on mathematical aesthetics and the geometrical meaning may not be immediately obvious.
yaseen shah
32
i does not understand that in columbs constant where 4pi comes from
I guess you're referring to Coulomb's law:
[tex]F = \frac{1}{4\pi\epsilon_0} \frac{q_1q_2}{r^2}[/tex]
The factor of 4π is there just because of the way the constant [tex]\epsilon_0[/tex] (the "permittivity of free space") is defined. It's defined this way to avoid having extra factors of 4π in http://en.wikipedia.org/wiki/Maxwell%27s_equations" , which are used much more often than Coulomb's law in practice.(This is all in SI units; in the Gaussian units system, still widely used, the factors of 4π in Maxwell's equations are retained, and Coulomb's law doesn't have the 4π in it.)
The constant depends on the medium and we could write it as a straightforward constant(k) or ,what you are referring to,as 1/4pi*epsilon.The two constants are the same and in many problems it is easier to use the straightforward k but if we did there would be other problems where,because of spherical symmety,4 pi would appear in the final answer.Using the second form of the constant makes the 4pis cancel and for the majority of problems the second form is more convenient.
Hello yaseen
and hello cortiver .you just beat me to it
Good question. I have always assumed it corresponds to the unit sphere area of 4 pi steradians, but I could be wrong.
This is what you could say part of mathematical aesthetics, rather expressive of any more deep insights.
We have the mathematical freedom to define a "constant" as the product (or, for that matter, the sum) of two other constants, and we choose the one definition that gives the most "elegant" answers.
It does. In fact you have the area of a sphere there, 4pi r^2. The constant epsilon0 is chosen so that the factor 4pi r^2 can be understood geometrically. There is nothing wrong with getting rid of the 4pi though, but the geometrical meaning is slightly less obvious.
The geometrical meaning comes from Gauss's Law, which says that the flux of the electric field out of a closed surface surrounding a charge is proportional to the charge inside that surface. The proportionality constant is determined by how you measure charge (i.e what system of units you're using), 1/epsilon0 is most common, but you can chose it so that the 4pi cancels. In this context flux is basically the number of electric field lines crossing a surface. So it depends not just on the strength of the electric field, but also on the area of the surface. So for a sphere you have [itex]Flux = 4\pi r^2 E \propto Q[/itex].
FAQ: Exploring the Origins of 4π in Coulomb's Constant
1. What is Coulomb's constant?
Coulomb's constant, denoted by the symbol k, is a proportionality constant that appears in Coulomb's law, which describes the electrostatic interaction between two charged particles. It is also known as the electric force constant or the electrostatic constant.
2. Why is 4π present in Coulomb's constant?
The value of Coulomb's constant, k, is derived from the fundamental properties of the electric force and the unit of charge. It is a result of the choice of units used to measure these properties. In the SI (International System of Units), the unit of electric charge is the coulomb (C), and the unit of force is the newton (N). The 4π appears in the formula to ensure the units of k match the units of force and charge.
3. How was the value of 4π in Coulomb's constant determined?
The value of 4π in Coulomb's constant was determined through experiments conducted by Charles-Augustin de Coulomb in the 1700s. He performed various experiments to measure the force between charged particles at different distances and with different charges. Through his experiments, he derived the mathematical formula for Coulomb's law and determined the value of k to be 8.98755 x 10^9 N·m^2/C^2. This value includes the 4π term.
4. Is 4π present in other physical constants?
Yes, 4π appears in other physical constants, such as the expression for the surface area of a sphere (4πr^2) and the volume of a sphere (4/3πr^3). It is also found in equations related to electromagnetic radiation and quantum mechanics.
5. What is the significance of 4π in Coulomb's constant?
The presence of 4π in Coulomb's constant is necessary to maintain the consistency and accuracy of the units used in the formula. It also reflects the fundamental relationship between electric force and charge, which is described by Coulomb's law. Additionally, the value of 4π serves as a reminder of the historical experiments and discoveries made by Coulomb in understanding the nature of electric charge and force.
