MHB What is a concave function and how is it determined?
  • Thread starter Thread starter kaliprasad
    Concave Function
A concave function, such as $\sqrt{x}$, is defined as one where the line segment between any two points on its graph lies strictly below the graph itself. This characteristic indicates that the function is concave downward, which is confirmed by its negative second derivative, $f''(x) = -\frac{1}{4x^{\frac{3}{2}}}$, for $x > 0$. The discussion emphasizes that while a negative second derivative is a common way to identify concavity, the formal definition involves the convexity of the set of points above the graph. Understanding these properties helps in determining whether a function is concave or convex. The insights shared clarify the mathematical definitions and properties of concave functions.
kaliprasad
MHB
I was reading some where that $\sqrt{x}$ is concave function what does it mean.
Mathematics news on Phys.org
Re: meaing of concave function
Hi kaliprasad,
From wiki, a real-valued function defined on an interval is called convex (or convex downward or concave upward) if the line segment between any two points on the graph of the function lies above or on the graph.
A concave function is the negative of a convex function.
Since the line segment between any 2 points on the graph of $\sqrt x$ lies strictly below the graph, it is strictly concave.
I had always thought of a concave function, or concave down, over some interval, as having a negative second derivative on that interval. If we have:
$$f(x)=\sqrt{x}$$
then we find:
$$f''(x)=-\frac{1}{4x^{\frac{3}{2}}}$$
Hence, we see that on the interval $(0,\infty)$ we have $f''<0$.
$$f(x)=\sqrt{x}$$
then we find:
That is, of course true, and often the easiest way to use "convex function", but is not the definition of "convex function". A set is "convex" if and only if, given any two points, A and B, in that set the line segment between A and B is also in the set. A function, f, is said to be "convex" ("convex upward" is typically implied by "convex" alone) if and only if the set of all points above the graph of y= f(x) is a convex set. The function is "convex downward" if the set of all points below the graph of y= f(x) is a convex set.
Thanks to all of you for the same. The property mentioned by MARKFL helps in chcking if the function is concave
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
