What is a False Vacuum? Understanding its Properties and Energy Differences
  • I
  • Thread starter KurtLudwig
  • Tags
    False vacuum
In summary, False vacuum is a concept in quantum physics that refers to a local minimum of the potential energy of a quantum field. There is a difference in energy levels between a false and true vacuum, and the laws of the Universe might change if this state transition happened.
KurtLudwig
31
TL;DR Summary
Please explain what a false vacuum is.
Is it a chamber with almost all gases removed? Why is the energy level higher than a true vacuum?
KurtLudwig said:
TL;DR Summary: Please explain what a false vacuum is.
Please first give a reference that shows the context in which you encountered the term. I could guess what I think the context is, but you should not be forcing people to guess.
Likes topsquark, vanhees71, Vanadium 50 and 1 other person
I read in a book by professor Katie Mack "The End of Everything (Astrophysically Speaking) in chapter 6 titled Vacuum Decay on page 143. A graph of False Vacuum versus True Vacuum energy levels was shown. Before asking Physics Forums for a more detailed explanation, I did look up on Wikipedia, again with no explanation what False Vacuum actually is.
My questions are: Is False Vacuum a chamber evacuated with almost no molecules of gases? Is it a concept in quantum physics? Why is an there energy level difference between a false and true vacuum? How do physicists know how the field value changes? I read somewhere that space is never totally empty do to quantum fluctuations. Why would the laws of the Universe change if it did happen?
This is a pop science book. You would be better served by reading actual textbooks or peer-reviewed papers.
Did you come across this page:
https://en.wikipedia.org/wiki/False_vacuum_decay
Try reading some of the many scientific papers referenced on that page. That should help to clarify what is being discussed.
No.
Yes. It occurs in two main contexts: first, inflation theory (in which the universe during inflation is in a false vacuum state), and second, speculative hypotheses about what might happen to our present universe in the future (involving the speculation that our current universe is in a "false vacuum" state).
The basic underlying idea is that, in quantum field theory, the term "vacuum" doesn't mean "nothing is present at all". It means the lowest energy state possible taking into account all quantum fields that are present and their current states. We usually assume that there is only one such state, but that is not actually true; it is possible in quantum field theory for certain state transitions (for example, the transition at the end of inflation in inflation models) to change what states are accessible and therefore which state is now the lowest energy state possible, the "vacuum" state.
More detail than that requires having a better reference as a basis for discussion.
All of these questions really should be answered by looking at a specific example. I would recommend reading papers about inflation theory first.
Likes pinball1970, KurtLudwig and topsquark
Vacuum in this context means "lowest possible energy", in QFT we still have energy even if there are no particles.
False vacuum means a local minmum of the potential energy of that quantum field. True vacuum means the global minumum.
Likes Vanadium 50, pinball1970, Bandersnatch and 3 others
Thanks for your explanations.
I will go back to Wikipedia to read False vacuum decay.
Not just the Wikipedia article itself but the references, at least some of which are actual peer-reviewed papers.
It is an I-level tag thread, I think reading the actual papers is beyond what an undergrad can cope.
Likes Bandersnatch
The subject itself is more suitable to an "A" level discussion. Looking at the actual papers will at least give the OP a start towards that level of understanding, if desired.
PeterDonis said:
the general topic of why PF's policy regarding pop science sources is what it is
Moderator's note: The subthread on this topic might get spun off into a separate thread.
Likes martinbn
FAQ: What is a False Vacuum? Understanding its Properties and Energy Differences
A false vacuum is a metastable state that appears stable but is not the lowest energy state of a field. In quantum field theory, it represents a local minimum of potential energy, which is higher than the true vacuum (the global minimum). Although it can persist for a long time, it is theoretically possible for it to transition to the true vacuum state.
How is a False Vacuum Different from a True Vacuum?
A true vacuum represents the state of lowest possible energy in a field, whereas a false vacuum is a local minimum that is not the absolute lowest energy state. The true vacuum is completely stable, while the false vacuum is only metastable and can decay to the true vacuum through a process called quantum tunneling.
What are the Properties of a False Vacuum?
The properties of a false vacuum include being in a metastable state with higher energy than the true vacuum. It can appear stable over long periods, but it is susceptible to decay. This decay can cause a phase transition, releasing energy and potentially altering the fundamental properties of the universe.
What is the Energy Difference Between a False Vacuum and a True Vacuum?
The energy difference between a false vacuum and a true vacuum is the amount of potential energy that separates the local minimum (false vacuum) from the global minimum (true vacuum). This energy difference is crucial as it determines the likelihood and consequences of the false vacuum decaying into the true vacuum.
What are the Implications of a False Vacuum Decay?
The decay of a false vacuum to a true vacuum could have catastrophic implications, potentially altering the laws of physics and the structure of the universe. This process would release a tremendous amount of energy, possibly resulting in a bubble of true vacuum expanding at the speed of light, fundamentally changing everything it encounters.
