What is a FET's ohmic region used for?
  • Thread starter jaydnul
In summary, FETs are commonly used in the active region for applications such as amplification, and can also be used as variable resistors in the linear region. Unlike FETs, BJTs do not have enhancement or depletion modes, but have depletion regions critical to their operation. FETs can be used as variable voltage-controlled resistors in linear oscillators to stabilize signal amplitude, as long as the voltage remains within a certain range.
jaydnul
558
The majority of FET applications are in the active region, right? (including amplification)
So what is the ohmic/linear region used for. Is it a reliable variable resistor?
Also, one quick off topic question: Do BJTs come in enhancement and depletion modes? Or is that just a FET feature?
Thanks
You are correct that generally one stays out of the linear region.
Here is something about FETs as variable resistors
http://www.vishay.com/docs/70598/70598.pdf
BJTs do not use enhancement/depletion effects like FETs do, although there are depletion regions in BJTs which are critical to their operation.
http://ecee.colorado.edu/~bart/book/book/chapter5/ch5_2.htm
Yes - FET`s can be (and are) used as variable voltage-controlled resistors. As an example, they are used in linear (harmonic) oscillators for stabilizing the signal amplitude.
In this application, a dc voltage is derived from the output signal (rectification) which is used to control the gate voltage of a FET - thereby reducing the loop gain before the amplitude will be clipped by the finite power supply. But keep in mind that for quasi-linear operation of the FET the voltage between drain and source must not exceed some hundreds of millivolts.
FAQ: What is a FET's ohmic region used for?
What is a FET's ohmic region?
The ohmic region of a FET (Field Effect Transistor) is a section of the device's current-voltage characteristic curve in which the current passing through the device is directly proportional to the applied voltage.
How is the ohmic region different from other regions of a FET?
The ohmic region is different from other regions of a FET, such as the saturation and cut-off regions, because it allows for a linear relationship between the current and voltage. In the saturation and cut-off regions, the current is not directly proportional to the voltage.
What is the purpose of the ohmic region in a FET?
The ohmic region is typically used for amplification and switching in electronic circuits. It allows for a linear response to small changes in voltage, making it useful for amplifying weak signals.
Can a FET operate solely in the ohmic region?
No, a FET needs to operate in multiple regions, including the ohmic region, in order to perform its intended functions. The ohmic region is just one part of the overall operation of a FET.
How is the ohmic region determined in a FET?
The ohmic region is determined by the bias voltage applied to the device. The bias voltage must be within a certain range in order for the device to operate in the ohmic region. If the bias voltage is too low, the device will be in the cut-off region, and if it is too high, the device will be in the saturation region.
