What is a limit of a sequence?
In summary, the conversation discusses the concept of limits and how to determine whether a sequence converges or diverges. The definition of a limit is stated as well as the conditions for a limit to exist. The conversation also addresses some common misconceptions about limits and provides examples for better understanding.
teng125
416
for lim n to infinity {2 [(-1)^n] },what should i write either converges or diverges because it tends to be -2 or +2
limit n to infinity
If I'm not mistaken, first thing you need to check in a series if the limit is unique , as in when the series limit is one number.
then you should check if that limit is zero or not , then you can apply usual methodes know to find out.
So in your case it diverge.
is it if there is (-1^n) and n limit to infinity means always diverges??
doesn't have to.
[(-1)^n]/n have a limit when n tends to be infinite 0 , this series converge.
I sense you don't know much about limits , maybe you didn't studied well that chapter.
it's fairly easy to know them.
Again, teng:
What is the definition of a limit?
"limit" is how a function's behavior changes when its argument(or variable) gets close to a certain value(or a point)
Not at all.
why is that?
Because what you wrote is meaningless.
Go back to your textbook and look up the definition of a limit to a sequence.
but ur question simply says
arildno :
u dint specify it was limit to a sequence...
i just thought u were saying abt limit of a function...so sorry
Nah, this is neither the definition for limit of a function nor limit of a sequence...
You may want to look it up in your book. :)
By the way, are you teng125?
Besides, a sequence IS a function.
OK, the lim inf is -2 and the lim sup is +2, and thus the lim is...
teng:
Forget subsequences, lim infs and all that.
Those concepts won't help you a bit, because you betray an uncertainness abut the very concept of a limit in the first place.
Let us take a typical textbook definition:
"We say that a number L is a LIMIT of a sequence [itex]a_{n}[/tex] if for any [itex]\epsilon>0[/itex] there exists a number N, so that for any n>N, [itex]|a_{n}-L|<\epsilon[/itex]"
Furthermore, a sequence is said to diverge if no such number L exists.
1. The first thing to note is that L (if it exists) is a NUMBER, and only that.
It is not a hand-wavy action by which we describe the function's behaviour. It is a number. Period.
2. Secondly, the definition should be regarded as a recipe of detemining whether or not an arbitrarily chosen L is a limit to the sequence or not.
3. Let us for convenience sake pick L=2 first, and check whether it can be said to be a limit to the sequence:
Consider the absolute valued difference: [tex]|2(-1)^{n}-2|[/tex]
Now, when n is even, this difference equals 0, but when n is odd, the difference equals 4.
Thus, by picking [itex]\epsilon<4[/itex], and remembering that odd numbers can be arbitrarily big, we see that there cannot exist a number N so that for ANY n>N, the difference is less than [itex]\epsilon[/itex]
Thus, 2 cannot be regarded as a limit L to our sequence.
Do you think -2 can be a limit?
What about any other number?
Answer those questions, and you have the answer to your own question.
FAQ: What is a limit of a sequence?
The limit of a sequence is a number that the terms of the sequence approach as the number of terms increases. It is the ultimate value that the sequence tends to, but may not necessarily reach.
How is the limit of a sequence calculated?
The limit of a sequence can be calculated by evaluating the terms of the sequence as the number of terms approaches infinity. This can be done algebraically, graphically, or by using mathematical formulas.
What is the importance of a limit of a sequence in mathematics?
The limit of a sequence is an important concept in mathematics as it helps us understand the behavior of a sequence and its ultimate value. It also has applications in calculus, real analysis, and other areas of mathematics.
Can a sequence have more than one limit?
Yes, a sequence can have more than one limit. This is known as a divergent sequence, where the terms of the sequence do not converge to a single number, but rather approach different values.
What is the difference between the limit of a sequence and the limit of a function?
The limit of a sequence refers to the behavior of a sequence of numbers, while the limit of a function refers to the behavior of a function as the input approaches a certain value. However, both concepts involve the idea of approaching a specific value or number.
